Two Coats Of Primer And Thinking About A Third...? - Painting - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 11:36 PM   #1
Two coats of primer and thinking about a third...?
I have new drywall and have primed with two coats of BM super spec. After the second coat the tape joints, pencil marks and color of the green board (blue board in this case) are still showing through. Is this normal or should apply another coat of primer?
MGravie is offline   Reply With Quote
Old 12-18-2012, 11:50 PM   #2
DIY staff
Rewards Points: 7,174
Perfectly normal---the primers job is to seal the surface and provide a good bond between the surface and the new paint----
It's not a paint and 'see through ' is fine---one very popular primer -Guards--is clear---
A very light sanding to knock off any boogers is a good idea---Mike----
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
Jay 78 (12-21-2012), jsheridan (12-19-2012), ToolSeeker (12-20-2012)
Old 12-19-2012, 07:17 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
Don't put on more primer. Paint it! Paint has more pigment and will do the hiding.
Normal routine is one coat primer ( Lightly sand) 2 finish coats
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-19-2012, 07:20 AM   #4
Gymschu's Avatar
Rewards Points: 846
Normal to see the joints showing through as the primer soaks into the mud differently than it does on the actual blue board.
As BJ said, lightly sand, remove any excess dust from the sanding, and, apply your finish coats.
Gymschu is online now   Reply With Quote
Old 12-20-2012, 09:38 AM   #5
Rewards Points: 394
Some times on new drywall, a high build primer is used to raise the finishing level (Level 4 or 5), where the joints do not show. As stated , the paint finish coat should provide the hiding.
Will22 is offline   Reply With Quote
Old 12-21-2012, 05:32 PM   #6
Rewards Points: 512
yup one coat. next time get your primer tinted close to the color your going to paint the wall so you dont see through the drywall so mentally you feel better and to not think it needs a second primer coat.
princelake is offline   Reply With Quote
Old 02-08-2013, 01:43 PM   #7
Grants Painting's Avatar
Yea primer is meant to BOND or SEAL or SMOOTH OUT(undercoater). Its not what hides the color underneath. Some do cover better though.
Primers and how to use them
Grants Painting is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Self-stick vinyl tile primer question. Jim F Flooring 5 11-12-2010 07:28 PM
Exposed OSB Primer aero Painting 1 09-12-2010 01:30 PM
Used primer without stirring and now concerned pstoll Painting 1 07-21-2010 10:06 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
