Tweaking Outside Miters - Painting - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 09:52 PM   #1
Rewards Points: 278
What do ya'll use when outside miters are no everso perfect ?
Caulk or Ready Patch to just fill in the minor gap prior to painting. I plan to do either and also shoot 2 23awg pinners in it.
mobiledynamics is offline   Reply With Quote
Old 07-17-2012, 10:45 PM   #2
Too Short? Cut it Again!
Caulk does not have a lot of structural stability to it and might get dinged up on an outside corner if it is part of a baseboard or chair rail. I guess if it is part of crown over your head you have no worries.
I would lean toward using the ready patch or even an epoxy type wood filler if they are way off. You can sand or otherwise tool them to shape too---caulk not so much. I usually have some of the material from Abatron around but the paint store will have other brands. With epoxies always make sure they are within the manufacturers expiration date.
Old 07-17-2012, 11:37 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
The only problem with wood fillers is they will tend to crack and not flex with the wood. I would lean towards caulk.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-18-2012, 01:25 AM   #4
Rewards Points: 13,276
I use Alex 230 and never had a problum.
Old 07-18-2012, 01:57 AM   #5
Old 07-18-2012, 08:13 AM   #6
Rewards Points: 278
It's not terribly off...just minor gaps. I was thinking of filling with caulk - with excess - and just cut the extra off - following the sharp line of the edge. Bad idea ?
Tweaking Paint Color in Different Rooms? Twister Painting 8 11-23-2011 10:27 AM
Range hood wiring needs tweaking RedHelix Electrical 4 12-02-2010 02:31 PM
Crown miters BlueBSH Building & Construction 7 07-26-2010 12:21 PM
