TV Background Color - Painting - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 07:49 AM   #1
Rewards Points: 264
TV background color
We had a small closet in our den, 46" wide by 25" deep. Got rid of the by-pass doors, drywalled, built in a cabinet from floor to about 32", added electric and cable, some adjustable shelves and set the TV and stereo there.
I want to know from you all what color you think would be good for the interior of the space? I was thinking flat black would help the TV blend in and the picture pop. The surrounding wall will be BM pale oak Aura eggshell.
7echo is offline   Reply With Quote
Old 07-14-2012, 08:34 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
I did something like that for my brother with a blackened red. Looked nice without being distracting.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-14-2012, 08:55 AM   #3
Rewards Points: 264
Do you recall the color code or name?
Old 07-14-2012, 08:41 PM   #4
Too Short? Cut it Again!
Warm dark gray.
Old 07-15-2012, 07:10 AM   #5
BM AF-305 I used Aura matte
Old 07-16-2012, 10:33 AM   #6
Flat black, only. It will look like the TV is floating in a black hole, with zero distraction. Any color and you will see what's back there, any sheen and it will reflect light and be visible.
Old 07-20-2012, 10:10 AM   #7
Rewards Points: 610
Good advice from JSheridan...I was thinking the same thing..FLAT BLACK all the way. No reflection!
techpappy is offline   Reply With Quote
Old 07-20-2012, 10:30 AM   #8
If you go flat black, get a factory and not a store tint mix. Have it shaken but also plan on stirring it awhile before and while putting it on. My Benjamin Moore supplier had the University of Illinois account and special ordered a super flat black for them and sold me some. It was not Ben Moore but worked great except that it was unforgiving when it came to smudges of any kind.
Old 08-03-2012, 08:51 PM   #9
Rewards Points: 264
So the very flat black will smudge? That could be an issue as I will be moving things around and will likely bump the wall and push things against it.
I will try for a factory mixed flat black at my BM store. The space is small so I won't mind if I have to try a eggshell as well.
Thanks for the comments.
Old 08-04-2012, 07:58 AM   #10
Rewards Points: 54
A neutral grey is actually best. You really shouldn't be watching tv in a completely darkened room. Having a black background in a darkened room will lead to eye strain if you watch for any length of time. Grey will not be as drastic a contrast and will not affect the colors you see on the tv. For example, a red background will make colors on the tv appear to have a red tinge
wetech is offline   Reply With Quote
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 07:27 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
New Roof Color Alto Roofing/Siding 3 08-27-2010 01:14 PM
Fade of new grout color. Bud Norris Flooring 7 06-16-2010 12:32 PM
Need help with wall & carpet color scheme Cruciatus Interior Decorating 6 04-05-2008 01:50 PM
