Turning White To Antique White - Painting - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 10:22 PM   #1
turning white to antique white
Is there anything I can add to a small cupfull of white paint to make it more antique white? I patched some holes in the wall with drywall mud, sanded smooth and touched up with what I had on the shelf. It just doesn't match very well. I'd like to play around with adding something to make it less white. I sure don't want to paint the whole huge wall right now. Thanks.
rustyedge is offline   Reply With Quote
Old 09-29-2010, 01:47 AM   #2
Rewards Points: 150
What is the shade of antique white? Can you describe it? Is it grayish or creamy? If you want the grayish shade, add a little tint of black to the white paint. If you want it to be creme-like, add a tint of yellow paint. It is wise to sample a small amount first.
MagicalHome is offline   Reply With Quote
Old 09-29-2010, 04:10 PM   #3
x2
start with small amounts to tint and stir well
racebum is offline   Reply With Quote
Old 09-30-2010, 10:16 AM   #4
Rewards Points: 558
There are a few ways to do this.
The first way is by using a few drops of brown paint or dark stain. Any type of brown paint will work, whether it's your child's finger paints, or an old can in your garage. Just remember, only a few drops at a time to tone it down, until you reach the desired color.
Another, more old-fashioned, way to do this is with tea or coffee. This technique has been used for many years to dye fabric or alter colors. The trick is to use the slightest amount (just as with the brown paint) until you reach the color your need. If using coffee, you will brew 5 table spoons with only 1/4 cup of water, and then let it set for a minimum of 3 hours before mixing. With tea, you can place a tea bag into hot water for a few minutes, then squeeze the bag out into the can, stir and repeat as needed.
The process is nothing more than adding a hint of brown, or even tan, to the white paint to give it the off-white color.
epson is offline   Reply With Quote
Old 09-30-2010, 10:28 AM   #5
I agree, definitely test first... You can also go to your favorite paint store and purchase universal colorant, raw umber would likely do the trick, but go slow this is a concentrate not paint it will turn your color dark very fast.
www.PearlPainters.com
Painters Sherwood Oregon
Pearl Painters is offline   Reply With Quote
Old 09-30-2010, 06:52 PM   #6
An inexpensive fix for this might be to go to a Michael's craft store and get some of their Craftsmart acrylic paint in 2 oz. bottles (I think they are 50 cents each) in colors like raw umber and raw sienna. These paints won't affect the gloss of the mix unless a lot is added.
Harpmaker is offline   Reply With Quote
Old 10-01-2010, 01:08 PM   #7
Rewards Points: 150
take the paint back to where it was purchased and have them tint it to their antique white. should not cost anything.
hammerheart14 is offline   Reply With Quote
white paint turning yellow victor Painting 40 11-13-2012 10:09 PM
Fresh painted white baseboards turning yellow laurenkemp7 Painting 2 09-01-2009 09:26 AM
Painting white martinigirl Painting 3 04-26-2009 07:24 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
