Old 11-05-2012, 01:59 PM   #1
Turbine HVLP w/pressure pot
Hello. I have a turbine driven HVLP sprayer from Campbell Housfeld and it works great, but the paint can is small. So I bought a pressure pot. I'm wondering what pressure I should set the pot to. I played around with it and got the pressure to where the paint would spray nicely but then I noticed a fine mist in the air - clearly, the pressure was too high.
Anybody have any advice?
Thanks,
-Jamie
jfalesi is offline   Reply With Quote
Old 11-05-2012, 02:43 PM   #2
Mr. Paint's Avatar
Your air is too high; cut down the pressure until you just have a good fan without tails.
Be sure not to over-thin the product. Thin it according to directions, usually will be just enough to get a good fan.
Spraying will always produce some overspray; a good HVLP system will have the least.
Mr. Paint is offline   Reply With Quote
Old 11-06-2012, 10:31 AM   #3
It is always a good idea to test spray it on scrap material (drywall, cardboard) to assess the spray pattern and distribution. Adjust the pressure and test prior to moving on to your finish work. HVLP sprayers, I agree, have very good transfer efficiency.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
ToolSeeker (11-06-2012)
Painting kitchen cabinets, Wagner HVLP conversion gun? Cobrakillert Painting 24 03-27-2013 05:26 PM
HVLP spraying help drewid153 Painting 6 08-29-2012 05:19 PM
turbine vents and ridge vents rhlhomeowner Roofing 3 09-30-2011 09:11 AM
Paint for HVLP sprayer Mike in Arkansas Painting 6 01-24-2010 05:44 PM
Spraying with HVLP ponch37300 Painting 4 04-20-2009 01:53 PM
