Tung Oil On Luan Door - Painting - DIY Chatroom Home Improvement Forum
Old 12-06-2013, 04:10 PM   #1
In a little over my head
Rewards Points: 706
tung oil on luan door
I am about to hang a new interior door. All the other doors in the house are painted, but I'm thinking of leaving this one wood. I really like using "Tung Oil Finish" on other wood projects. Any thoughts pro/con on using it here? It's hard to test on the door, because there really aren't any "inconspicuous" areas on a door. Stain first?
ratherbefishing is offline   Reply With Quote
Old 12-06-2013, 05:03 PM   #2
Rewards Points: 13,732
Makes no since to me.
Why not match all the other doors?
Old 12-06-2013, 07:29 PM   #3
K&B Designer
Live_Oak's Avatar
There's a reason people paint luan. It's ugly. If you want a paint grade door, go buy something worth fussing over with for staining and clear coating.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
gregzoll (12-06-2013)
Old 12-06-2013, 11:11 PM   #4
Rewards Points: 386
Wow...
I'm not exactly sure RBF was asking for anyone's approval - and never really asked if it made "since" to anyone else...and I have varnished Luan doors throughout my house and always thought they looked great - but now I'm told they're ugly? hmm...the things we learn on this here chat line.
Personally I'd rather see a varnished, or oiled, Luan door than a painted one - but that's just me. To answer your question, Tung oil would be fine on a Luan door - it'll add a bit of color, but that helps to bring out the natural color of Luan making it a deeper and richer color. If you're considering a straight Tung Oil (as opposed to a tung oil varnish), you're probably looking at 3 - 4 applications to get a good & consistent satin finish. If you're going to stain the door, obviously do that first before oiling - and be careful, Luan takes stain quick and deep, but consistently...If you need a scrap piece to test a stain (or oil) on, you can buy inexpensive Luan panels at any big box and they'll stain exactly as your door will. Good luck to you.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
ToolSeeker (12-07-2013)
Old 12-07-2013, 09:15 AM   #5
Rewards Points: 706
Thanks, Ric. Buying a small piece of Luan at the local HD sounds like the way to go. I think they might even have 2'x4' pieces in their "hobby" section. Now that I think of it, I bet the millwork shop up the street that made the door has a pile of scraps. I'm off...
Old 01-04-2014, 10:22 AM   #6
Rewards Points: 706
I just realized that I never finished the thread. After a few days of indecision, I decided to try the tung oil. Figured it would be easier to sand the varnish so paint would stick than vice versa, if I changed my mind. Three coats of Behr Scandinavian Tung Oil finish later, the door looks great. The edges are nothing fancy, sort of a varnished fiberboard. But the finish really enhanced the grain and even made it sorta iridecesent in places.
The Following User Says Thank You to ratherbefishing For This Useful Post:
ric knows paint (01-04-2014)
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
Leaking Door JaneD Windows and Doors 2 06-15-2011 08:22 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
