Old 12-30-2012, 08:45 PM   #1
call me E
TheEplumber's Avatar
Tub Rust Repair
I need to address these rust spots in a painted steel tub- it's actually a baptistery at my little church I attend. Any suggestions would be appreciated.
(for some reason the image doesn't show in "post preview" so if its not in the actual post- I'll work at it)
Old 12-31-2012, 08:58 AM   #2
cdaniels's Avatar
Tub Rust Repair
You can buy an epoxy kit from Home Depot or Lowe's that includes everything you need. Just follow the directions.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 12-31-2012, 09:56 AM   #3
Gymschu's Avatar
Tub Rust Repair
I would try to sand the rust off down to a sound surface. Sometimes sandpaper does the trick or you may have to use a small multi-tool to gently grind/sand the rust off. Once you get the rust off, you could spot prime those areas with a rust-converting primer or a rust inhibiting primer. Allow that to dry and then touch up with a white metal paint or an all-surface paint that closely matches the white color of the baptistry. This might save you from having to recoat the entire thing with an epoxy.
The Following User Says Thank You to Gymschu For This Useful Post:
TheEplumber (12-31-2012)
Old 12-31-2012, 12:48 PM   #4
call me E
Tub Rust Repair
That's the general approach I was considering. A half-hardy attempt was made previously by someone else, so it's my turn.
I'll take my small grinder with a wire wheel to it, research some good inhibitors and paint- see what happens.
The Following User Says Thank You to TheEplumber For This Useful Post:
Gymschu (12-31-2012)
What's a good product to repair chip in steel tub to prevent rust? amodoko Plumbing 4 12-26-2011 09:37 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 07:02 AM
