Tub In Bathroom Needs Refinish - Painting - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 05:04 PM   #1
Tub in Bathroom Needs Refinish
My tub is in a sorry state. I saw a kit to refinish it in a hardware store for $50, but I am worried that I won't be able to get the finish that I see on the box. Is this an easy task or should I call someone in to do it. Here's what I'm dealing with:
CrankyDragon is offline   Reply With Quote
Old 10-20-2010, 06:05 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
That tub was already refinished. You see what the results are. I have never had anyone tell me a tub refinish has lated more than a few years.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
CrankyDragon (10-21-2010)
Old 10-20-2010, 06:09 PM   #3
Rewards Points: 258
I doubt that you will be satisfied with the results from a $50. kit. Either have it done professionally or replace the tub. If it were me, I'd just replace the tub.
retired guy 60 is offline   Reply With Quote
The Following User Says Thank You to retired guy 60 For This Useful Post:
Old 10-20-2010, 06:44 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
The right way to re finish a tub is to first use the right products, midwest chemicals has great refinishing products, use an hvlp sprayer, and use a special heat lamp that will instantly cure the finish, but for a diyer to purchase the tools necessary it would cost thousands. The heat lamp along is $1,500. If done correctly it will last a long time. In your situation I would either call a refinishing company or just replace the tub
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Old 10-21-2010, 11:18 AM   #5
It never occurred to me that it had already been refinished, but now that it has been pointed out it seems obvious. Thanks. I will look into both options and stay away from doing it myself this time.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
