TSP On Lead Paint - Painting - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 09:13 PM   #1
Rewards Points: 43
TSP on lead paint
Is it safe to use TSP to wash down a wall that is (possibly) lead paint? I wouldn't use TSP, except the existing paint is quite glossy and I've had trouble getting new paint to adhere to it in the past.
bugmenot is offline   Reply With Quote
Old 06-12-2012, 09:19 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
It is actually a recommended way of prepping , because it is wet and doesn't cause dust. Toss the waste water down the toilet.
For extra good prep you can even wet sand with the tsp.
Wear gloves and use precaution with TSP hitting other surfaces.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-13-2012, 07:26 AM   #3
Too Short? Cut it Again!
You will be fine. Most of the stuff is faux TSP now anyhow.
Old 06-13-2012, 04:17 PM   #4
Environmental Health
TSP + Lead Based Paint = Lead Phosphate, which is a carcinogen.
Dean CRCNA is offline   Reply With Quote
Old 06-13-2012, 04:19 PM   #5
So is Tar- but I don't eat the road. Dean, rather than scare, how about real info on how to deal???!!
Old 06-13-2012, 04:25 PM   #6
Gymschu's Avatar
Rewards Points: 846
So is air! LOL.
Gymschu is online now   Reply With Quote
Old 06-14-2012, 04:51 PM   #7
ltd
Rewards Points: 536
first off check to see if it is lead paint you can get lead test swabs at paint stores ,8 for about 20 bucks .i think i seen test swabs at the big boxes 2 for about 8 bucks . of course how the heck do i know if your wall has lead paint. hey i'm sitting in my big chair totally wiped out from painting all day.but i can tell you i have painted many homes from the early fifties and sixties that did not have lead paint on the walls . now trim is another story . .even if their is its probably covered over wit coats of non lead paint but again who knows.just test it the directions are easy and they have demos on you tube .ok how i would do it is spot clean any grime then a coat of zinsser oil base cover stain bonding primer .then top coat your favorite latex paint
ltd is offline   Reply With Quote
Old 06-14-2012, 04:56 PM   #8
Mr. Paint's Avatar
Most paint stores sell lead test kits. I think it wise to find out for sure if you are dealing with leaded paint rather than be put off by a possibility. TSP substitute cleaner will de-grease and de-gloss a surface so that you can use a high-quality adhesion promoting primer and acrylic finish.
Mr. Paint is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Stud finder and lead based paint? thunderhead Electrical 1 07-24-2011 06:49 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
Lead Paint Densec Painting 2 06-23-2010 09:49 AM
