Trying To Match Wall Texture - Painting - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 07:43 PM   #1
Rewards Points: 264
Trying to match wall texture
House was built in 1965 and the bathroom walls have a texture that looks like an orange peel. Is there a roller on the market that will create the same effect or is there another way? I installed windows and the finished drywall around window openings is smooth.
Also,the rest of the house has a slight texture that puts you in mind of someone putting paint on a roller and after rolling it the first time it has that kind of look. Meaning under normal circumstances one would keep rolling back and forth to spread it out creating a sand finish? The look is uniform I just don't know if they sprayed that look on back in the 1960's but how do I recreate it?
Pawl is offline   Reply With Quote
Old 03-12-2012, 07:54 PM   #2
Rewards Points: 14,306
There's at least 100 differant way to texture a wall or ceiling.
A picture of what you have may help.
See if it looks like this.
http://homerepair.about.com/od/inter...r_tex_wall.htm
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Some tips on matching spray wall texture - have a pic theedudenator Painting 1 01-08-2011 04:39 AM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 11:57 AM
texture on wall vs. spackled spots diylady Painting 9 12-19-2007 02:01 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
