Trouble Scraping Paint Off Brick HELP! - Painting - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 10:43 PM   #1
trouble scraping paint off brick HELP!
I am trying to scrape 150 years of paint off brick and it is as hard as concrete in places. A regular scraper only takes the loose stuff off. The rest needs a hammer and chisel and I have about 1300 s/f left to do. I just bought the Spyder reciprocating saw scraper blades THEN read the lousy reviews of the product when I got home. Haven't tried it yet but I'm thinking of returning it before I break it. I can't use a pressure washer or sand blaster because the mortar is too fragile for either. I have never used a heat gun but I doubt it will make a dent on this stuff. The building has been scraped and painted many times before but they never got all the paint off. There are a lot of plateaus of many layers of paint, then areas where the brick is under one or two layers of paint. Any suggestions?Thank you
h82diet is offline   Reply With Quote
Old 04-13-2012, 01:16 AM   #2
Rewards Points: 526
It is very easy to damage historic masonry. Bricks from 150 years ago are much softer than bricks made today.
Windows is offline   Reply With Quote
Old 04-13-2012, 02:05 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Use a Gel type Paint Stripper similar to this:
http://www.amazon.com/Citri-Strip-QC...QFCP1G/ref=sr_
Use a fairly stiff polyester or Polypropylene brush to apply it.
Ask at your local paint store.
Take appropriate precautions. Those bricks are loaded with Lead.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-13-2012, 04:31 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
Are you trying to expose the original brick? Why do you need to get ALL the paint off?They make many different kinds of blasting materials that will not harm the morter( very much)
Old 04-13-2012, 10:06 AM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If you need to remove all of the paint Peel Away smart strip will work, but it will be costly on the whole building and stilll takes some work.
housepaintingny is offline   Reply With Quote
Old 04-13-2012, 10:39 AM   #6
Rewards Points: 256
You might want to try calling "American Building Restoration". They specialize in matters like yours.
If this company doesn't have it, no one does. http://abrp.com/
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 04-13-2012, 06:21 PM   #7
Mr. Paint's Avatar
Peel-Away is good, but this may be better suited to the job. Back-To-Nature strippers work overnight. They are non-caustic and environmentally safe. They are owned by Sunnyside Products. Check it out:
Mr. Paint is offline   Reply With Quote
Old 04-13-2012, 07:16 PM   #8
Tool Geek
PaliBob's Avatar
Here is a link to that 'Ultra Strip' paint remover
http://www.jamestowndistributors.com...uct.do?pid=800
Here is another very environmentally safe product.
http://www.amazon.com/SoyGel-Urethan...4358602&sr=1-3
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
Mr. Paint (04-16-2012)
Old 04-13-2012, 07:23 PM   #9
I used Ultra strip one time and it worked pretty good for me!
chicagoremodeli is offline   Reply With Quote
Old 04-13-2012, 08:05 PM   #10
Tool Geek
PaliBob's Avatar
http://www.amazon.com/Spyder-1002D-2.../dp/B002HYAB60
Jill, I hope you sent that blade back. A reciprocating saw with that blade is going to remove more brick than paint.
If paint is that thick, I would try this first:
http://www.amazon.com/Lisle-52000-Ra.../dp/B0002SR88C
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-13-2012, 08:17 PM   #11
Rewards Points: 616
Peel away smart strip is also non caustic and environmentally safe. Peel away smart strip pro usually starts to work after about 3 hours of dwelling depending on temps and neither of them need to be neutralized. We stripped a historical brick building last year using peel away smart strip, now we are stripping another historical building using peel away smart strip pro. Either way you go, there is still work involved. Even using chemical strippers.
Old 04-13-2012, 10:05 PM   #12
Tool Geek
PaliBob's Avatar
Peel Away is 25% cheaper than Ultra Strip which runs $6o/gal on one site.
http://www.amazon.com/Smart-Strip-Pe.../dp/B001F0KO2S
Here is a video of Peel Away on brick:
Disclaimer
& Stay Safe
.....Bob Lavery
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
removing oil based paint off of brick handycanuck Painting 1 06-18-2010 01:14 PM
Bad Bad Paint job to fix. Cleaning brick overspray and other problems. (Pics) ewheatley Painting 1 05-19-2009 02:08 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
