Trouble Getting Flat Surface On Doors/trims - Painting - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 07:51 PM   #1
Trouble getting flat surface on doors/trims
I've been repainting some doors and trim. The existing top layer of was not well adhere in some places and started to flake when sanding. So I have stripped the top layer, then sanded, but it seems like there are still slightly raised ridges (wood grain?) which is visible once I paint the satin top coat.
I'd been using a small sanding block, do I need a very large flat sanding tool? Do I need to fill these somehow? It would mean applying putty over a large area.
JakeS is offline   Reply With Quote
Old 08-19-2009, 09:42 AM   #2
Coatings Nerd
If its the paint thats producing the raised edges, sanding is about the best way to get rid of them. Show us a pic so we can see exactly what it is.
Me personally, I hate doing what you're doing ( sanding ). I would sand the doors and just replace the trim.....but that's just me.
NCpaint1 is offline   Reply With Quote
Old 08-21-2009, 02:13 PM   #3
Rewards Points: 506
Once the raised edges are knocked down again, try sealing with oil-base primer before topcoating.
sirwired is offline   Reply With Quote
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Another name for surface wiring/wire-mold? fw2007 Electrical 4 01-09-2008 05:56 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
