Trim Problem ? - Painting - DIY Chatroom Home Improvement Forum
Old 10-01-2007, 12:39 PM   #1
Trim Problem ?
Greetings--
Contracted painters to paint existing wood trim.
Existing trim had white gloss paint on it. Applied gloss latex.
New paint has been applied and drying for 2-3 days now. Paint is still "sticky". It appears to peal off in places as well.
Question-- Was this applied improperly ? If so, how should the contractors have approached this ?
If improper, what is the fix ?
Thanks--
Piney is offline   Reply With Quote
Old 10-01-2007, 03:46 PM   #2
need a lot more info.
was existing trim painted with oil?
was it cleaned and sanded prior to latex paint being applied?
What does the painter say is happening?
Big Bob is offline   Reply With Quote
Old 10-01-2007, 06:17 PM   #3
Workaholic's Avatar
Rewards Points: 268
It sounds like there was gloss oil originaly and that latex was applied for the top coat? Is this possible? There are a couple other possibilities.
The paint should of dried days ago.
Need more info to help.
Sean
Workaholic is offline   Reply With Quote
Old 10-01-2007, 08:06 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Interior, exterior?
Exact type (brand & line) of paint?
Humidity, temp, other climate/weather conditions?
slickshift is offline   Reply With Quote
Sidelight - Cannot find vinyl trim lrichards Building & Construction 2 08-28-2008 04:42 PM
How to paint trim, fascia? martyshel Painting 7 08-10-2007 09:48 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 08:49 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
