Trim Paint Sequence? - Painting - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 05:30 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Trim paint sequence?
1. Caulk, prime and paint?
2. Prime, caulk and then paint?
MikeKy55 is offline   Reply With Quote
Old 08-26-2011, 05:44 PM   #2
Gymschu's Avatar
Rewards Points: 462
I've done it both ways but I prefer Prime, caulk, paint. By priming first you give your caulking something solid to stick to & priming first exposes areas that you may not have seen previously that need caulk. Having said all that, there are times I caulk first especially if I have a sound surface to begin with. Also do it sometimes when you're doing a budget job (apartments for instance) and quick coats of paint are necessary.
Old 08-26-2011, 05:47 PM   #3
ltd
Rewards Points: 536
ltd is offline   Reply With Quote
Old 08-26-2011, 05:54 PM   #4
MikeKy55's Avatar
Rewards Points: 254
Makes perfect sense, thanks guys!
Old 08-26-2011, 06:18 PM   #5
m1951mm's Avatar
I agree,
1. Prime
2. Caulk
3. paint the reveil on the trim
4. cut in the wall paint.
5. paint the walls.
6. finish coat the trim, the flats since the reveil is already painted.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
Eric13 (09-17-2011)
Old 08-26-2011, 10:36 PM   #6
Too Short? Cut it Again!
Must we discuss this over and over again. Does anyone use the search engine?
Prime first. Caulk of course second. With paintable caulk and not silicon breast implant material.
I always finished the trim first, completely. Easier to cut in wall paint to trim than try to paint the 1/2" wobbly edges where trim meets plaster walls.
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
