Trim Paint - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 10:58 AM   #16
Matthewt1970's Avatar
Rewards Points: 1,098
I would still go with the Superspec. You already have one coat on it and changing sheens or brands could mean 2 more coats if you do not put a very solid coat over your superspec.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 03-05-2012, 02:43 PM   #17
Aura will dry faster so you have to put it on and leave it - for linear trim, this is actually easy to do (doors can be more problematic). Advance just loves to flow and has long open time so you cannot load it on or it will sag. Unlike Aura, you can go back into it to fix any sags or runs but since it is an alkyd, some slight yellowing is possible. However, this would only be noticeable in a clean white.
Paintguy is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 05:04 PM
