Trim Caulking Before Paint? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 11:22 PM   #16
Originally Posted by MikeKy55 View Post
Thanks everyone! But I really appreciate you taking the time to detail this like you did. Saved to my hard drive. I may quote you one day.
Not a problem, just spell my name right.
Old 08-13-2011, 11:36 AM   #17
Registered User
Rewards Points: 526
LOL, ------ never caulk above or below metal z-flashing. Caulking above seals the end-grain (edge) of sheathing where it drains out if ever wet inside, sealing under metal could retard expanding/contracting of trim until caulk joint fails and provides easy entry for wind-driven water by capillary action as the caulk would bridge (negate) the drip-edge it had before.. Thanks for sharing......
Gary
Old 08-13-2011, 12:01 PM   #18
Gary
I've never seen that myself Gary, especially on the underside of the z. Why would someone think the need to caulk that. On the top I could see if the bottom edge of the siding wasn't primed and the water sitting on the sill of the z was wicking up into the siding. I would agree, that as a matter or routine, never caulk that area. But, sometimes you have to do what you have to do to stop moisture entry. The beauty of the internet/youtube is that anyone can have their own show, but it's a drawback as well.
Old 08-13-2011, 02:56 PM   #19
kwikfishron's Avatar
Rewards Points: 1,004
I always run a bead on top of the trim and seat the z to it so essentially I am caulking the bottom of the z but you just can't see it.
kwikfishron is online now   Reply With Quote
1st Steps in Painting? Qckrun Painting 7 12-15-2009 12:25 PM
exterior trim paint suggestions AGirlsGottaDoIt Painting 2 03-29-2009 11:06 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 05:04 PM
