#1 |
Trim caulking before paint?
Anyone care to share some tips on caulking new trim before painting the first time? Still working on the basement project....... I'm installing doors and base now. I know I will need to caulk the base where it meets the walls in some spots. My question is, do you caulk everything? tricks to limit the amount of mess and/or waste? The trim will all be white when I'm done. Thanks in advance.
#2 |
Painting Company, NY
Cut the tip at a 45 degree angle and don't cut it to large. Hold the caulk gun at an angle and use a wet rag to wipe away excess. Once you caulk for a while you will get the feel for the caulk gun and won't waste much.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to housepaintingny For This Useful Post: | MikeKy55 (08-11-2011) |
#3 |
Rubbin walls since'79
If it's new wood, or your painting over varnish(which needs to be sanded first), prime, caulk and fill holes-depending on topcoat- either re prime (because of spackle- or spot prime spackle), and 2 top coats of finish.
You will see what needs it so much easier after prime. caulking isn't easy- use sparingly and wipe it first with a finger, then a damp rag to get excess . |
#4 |
Thanks to both of you. I should have mentioned I'm using preprimed 3.5 inch base. I figured I would need to prime it all again before painting. I would like for it to be pretty slick when done.
#5 |
Before applying your caulk make sure that any joint compound around the baseboards is primed also. Caulk will not hold to raw drywall mud. I am in the camp of using a finger to smooth the caulk into the joint and then wipe with damp rag.
#6 |
paper hanger and painter
Trim caulking before paint? |
#7 |
I like my tips cut below 45 degrees, as I think 45 doesn't give as much pinpoint accuracy. I like the hole to be just wide enough to take a finish nail.
Keep the tip resting on the surface. Work the trigger with gentle, even, steady pressure. No pumping the trigger. Keep the gun moving. Your speed is how you adjust the amount applied. Don't surface fill joints. If you have a decent sized gap, move slower so the gap fills. If you move too fast you'll only apply enough to bridge the gap and the stuff will shrink and open up. Caulk everything. Technically, all wood joins should be caulked, whether they're gapped or not. What is tight and closed now might not be in six months after settlement, especially important exterior. Also, if you have a stretch of baseboard with caulked/non-caulked sections, it could be noticeable when you're done. Remember, you're altering a surface, and paint highlights altered surfaces. Use two hands. One on the trigger with the end of the gun cupped in the other, like a shotgun. Always work backwards into previously caulked areas. Apply your bead, not getting too far ahead, keep a wet rag, wet your finger to smooth. Wipe the excess on your rag. If you caulk doorframe mitres, fill the gap and rub it in/wipe with the rag. When you run down a door frame return, don't stop in the corner at the base, take it out on to the base an inch or two. When the frames are done, just run the base and connect the two door frames. Be sure that you dust the surface prior to caulking. For real tight detail work, you can use a small latex brush and a pot of water. Be mindful not to round your corners. Don't apply too much that you obliterate the 90 degree angle of trim joints. Use caulk to reinforce the drywall corners. Applying a bead of caulk around the ceiling perimeter also helps to get a nice clean cut line when you're working with high contrast colors. Get a good quality dripless gun. A cheap caulk gun is the worst possible tool anyone could buy. I use caulk for a lot of purposes, and I'm pretty anal about how it's applied. There is nothing more detracting to a paint finish than a lousy caulk job. Take your time. Joe Oh, and never caulk unprimed wood, gypsum, or other porous surfaces. It will draw the vehicle out of the caulk, it will lose its elasticity, and will fail prematurely. Always putty and caulk after priming.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by jsheridan; 08-12-2011 at 05:35 PM. Reason: add on |
| The Following 3 Users Say Thank You to jsheridan For This Useful Post: |
#8 |
Mod
You can always get a few good caulking tips from this guy.
http://www.youtube.com/watch?v=2jXgeSd-57A
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#9 | |
Trim caulking before paint?Quote:
#10 | |
#11 |
Mod
I thought you all would get a kick out of that.
![]() I personally like the dirt clods hanging off the tip.
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 08-12-2011 at 06:43 PM. |
#12 |
I've met guys like that. I worked alongside one one time, a guy in his late fifties, a lifer. I said Charlie, let me show you a trick with that gun. He says leave me alone, what are you doing. I said I'm just trying to show you how to be a better painter. He says, "I don't want to be a better painter." Nuff said Chal. That's legend, and is oft spoken of and relived when I'm in the presence of those on that crew.
Thanks Kwikfish, dirt clods, lol,lol.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#13 | |
NACE Coating Inspector
#14 |
Mod
Sorry to hear that, but it's your turn.
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 08-12-2011 at 08:24 PM. |
#15 | |
Thanks everyone! But I really appreciate you taking the time to detail this like you did. Saved to my hard drive. I may quote you one day. |
| The Following User Says Thank You to MikeKy55 For This Useful Post: | jsheridan (08-13-2011) |
| Display Modes | |
| 1st Steps in Painting? | Qckrun | Painting | 7 | 12-15-2009 01:25 PM |
| exterior trim paint suggestions | AGirlsGottaDoIt | Painting | 2 | 03-30-2009 12:06 AM |
| Removing latex paint from wood trim | ulbass | Painting | 1 | 03-12-2009 02:19 PM |
| Painting a room for new baby. Lots of questions. | SuperAkuma | Painting | 15 | 01-01-2009 11:18 AM |
| Exterior trim paint is peeling, wood is rotting! | firsthomenewb | Painting | 10 | 05-15-2008 06:04 PM |
