Old 05-07-2010, 03:44 PM   #1
retired guy
tree sap on deck
I just painted the first coat of stain on my deck and noticed that in one spot, tree sap has risen from the wood. What is the best way to remove the sap before applying the second coat? How long do I have to wait after removal? Thanks.
igneous is offline   Reply With Quote
Old 05-07-2010, 06:29 PM   #2
tree sap on deck
sometimes they will bleed out for a while. not sure what to seal with probably need to ask the folks you got your finish from what to use under it
The older I get the better I was
Old 05-08-2010, 07:46 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
tree sap on deck
Best solution:
Deck board removal and replacement
Those "bleeders" can cause havoc for years
...or never show up again
Any "fix" at this point "might work, might not"
slickshift is offline   Reply With Quote
Floating deck questions DIYguy2000 Building & Construction 6 04-23-2010 11:59 AM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 07:57 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
