Trailer Deck Paint - Painting - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 09:50 PM   #1
Trailer deck paint
Is there a durable paint (UV Resistant) that could be used on a utility trailer floor? I was going to use an epoxy garage floor covering, but I don't think they are UV resistant. The previous owner of my trailer painted the floor for some reason, and it looks like crap. I was hoping to be able to cover it with something.
pomelo is offline   Reply With Quote
Old 03-09-2010, 05:09 AM   #2
Too Short? Cut it Again!
You can get epoxies with UV protection or try a specialty industrial floor finish but is it really worth the cost for a utility trailer? Epoxy finishes are certainly durable but the resins will chip if you drop things on them. Could happen in a utility trailer situation?
Why not just use a paint store, not box store crap, quality urethane reinforced alkyd floor and porch paint and just touch it up every now and then if needed? Your choice of colors. Just prep the surface as no primer goes underneath. Paint store may not have the color you want since many do not stock a lot of the stuff but they can usually get it within a day or so.
http://www.benjaminmoore.com/bmpsweb...paint/prd_c112
Old 03-09-2010, 06:53 AM   #3
DIY staff
Rewards Points: 7,174
SDSESSTER has the method--Trailer decks get scraped and scratched--A high quality deck paint that can be touched up quickly is that I do.
Every fall I give it a light sanding and add one more coat.Cheap and easy. The epoxy will probably scratch up more easily than a deck and porch paint anyway.--Mike--
You didn't tell us what the trailer deck was made of--I assumed that it was wood,
If it is a steel deck I suggest Rust-oleum oil based enamel.--M-
Last edited by oh'mike; 03-09-2010 at 06:58 AM. Reason: To early in the morning-didn't think clearly--
Old 03-09-2010, 08:49 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I would sand, get as much of the old coating off as possible, clean well, then use treadplex primer followed by a top coat of tread plex, you can purchase it at Sherwin Williams.
housepaintingny is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
Bad Bad Paint job to fix. Cleaning brick overspray and other problems. (Pics) ewheatley Painting 1 05-19-2009 02:08 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
