Touching-up Painted Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 04:46 PM   #1
Rewards Points: 194
I have off-white cabinets that are showing a little wear and I'm ready to touch-up the areas that need a little TLC. The previous home owner was nice enough to leave behind the old paint can and tint ratio's. So, I was able to get the same brand and color scheme (Devflex HP semi-gloss 4216-001L).
The plan is to clean the cabinets well, sand any the areas that have the paint chips (a light sand just to remove the hard edge of the chipped area), and start painting. I am planning to remove the doors (a few at a time) and paint them in my garage while they are laying flat. I will be using a brush that the paint store recommended for this paint.
Are there any tips or things that I should know about before I start this process? Should I worry about temperature when using this paint? Here in California, my temperatures range from 55 degrees at night to 90 degrees during the day. Its also pretty dry here, so there isn't much humidity.
loftezy is offline   Reply With Quote
Old 09-17-2012, 05:46 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Sounds like you are on the right track. And it also sounds like you aren't touching up- but doing a full coat on the doors? This is the best way to go, it is difficult to make spot touch ups not show.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-17-2012, 06:15 PM   #3
Rewards Points: 194
Yes, I will be painting the whole door. I wanted to just paint the small areas that needed it, but the paint store assistant said that it would be nearly impossible to match the two colors exactly. He also said that the age of the original paint and its wear also make a difference in the color.
I'll start by practicing on some spare wood. I want to make sure that the brush strokes won't be too pronounced before I start on the cabinets.
Old 09-17-2012, 11:09 PM   #4
almost sounds like you went to a real paint store
Old 09-18-2012, 06:18 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 152
Maybe spot pime the bare spots after sanding.
Old 09-18-2012, 11:58 AM   #6
Rewards Points: 194
You nailed it!
I think I destroyed my cabinets, please help! chibear1986 Painting 7 12-07-2010 09:32 PM
Building partition wall behind base cabinets bluefitness Building & Construction 3 11-09-2010 07:49 PM
Help finding touch up product for kitchen cabinets RiseAgainst Painting 0 09-25-2010 08:22 PM
Distressing Cabinets lgallego Painting 2 08-18-2010 06:26 PM
Contractor built cabinetop that doesnt' fully cover cabinets jlynnrubin Remodeling 3 12-27-2009 10:43 AM
