Touching Up Flat Paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 01:44 AM   #1
Touching up flat paint
Hi don't get annoyed , I'm new. I'm not sure if the picture will show what's going on so I'll try to describe it too. I tried to touch up our flat dining room paint. There was some left in the garage from several years ago so I tried that and wherever I put the paint on, trying brushes, roller, foam, etc, it look like a dirtier wet version of the same color. So I got new paint mixed to match, tested it on the vents and it was perfect. So I put some on the wall (it had been several months since the first try and the wall wasn't wet from anything). I rolled on a 4x4 square and it looked like it would match when it dried, but a couple minutes later there was a frame about an inch wide around where I painted that looked water wet. Now it's 12 hours later and the new painted square looks like different dirty wet colors. The original paint has been on for 5 years with no problems besides kid scuffs and dirt that wouldn't come off. I have no idea what to do so any suggestions at all will be greatly appreciated.
Alicia
AliciaG is offline   Reply With Quote
Old 05-05-2011, 03:24 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
After 5 years, you need to paint the whole wall.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
jsheridan (05-05-2011), tcleve4911 (05-05-2011)
Old 05-05-2011, 10:37 AM   #3
Gymschu's Avatar
Rewards Points: 846
To me, touching up a wall is one of the toughest jobs in the painting biz. Using the original paint, I simply use a Whizz mini roller and gently roll over any marks, etc. sometimes just tapping the roller onto the mark so as to hide it without having to roll out an entire section of wall. Even if you have leftover paint, since it's been 5 years the color is not gonna match up due to sunlight fading the wall paint, dirt and dust on the wall, etc. And, as you found out, buying new paint that is close to the color is never gonna be close enough. As Chrisn said, you may be further ahead to just paint the WHOLE wall at this point.
Got Dark Paint on Flat white popcorn ceiling DIYAmatureLeah Painting 6 01-22-2013 06:10 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
cleaning fingerprints off flat paint Lethrneck4 General DIY Discussions 8 03-07-2010 10:46 PM
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 04:12 PM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
