-   -   Touching Up Builder's Grade Paint - HELP!! (http://www.diychatroom.com/f4/touching-up-builders-grade-paint-help-43056/)
candisue7 04-22-2009 09:40 PM
I rent a fairly new duplex and I'm moving out soon. I noticed the builder's grade paint scuffs REALLY easily so I used a Magic Eraser to get rid of the marks. The problem is, there are spots where the paint was so thin, it came right off. How do I touch it up? There are hundreds of different whites to choose from let alone different finishes. Do I ask for "Builder's grade" paint? Is there such a thing or is it all about the poor application?? Help!!!!!
chrisn 04-23-2009 06:29 AM
You will need to find whatever original paint was used and touch up, otherwise you need to pick a white and re do the whole wall
slickshift 04-23-2009 06:55 PM
Ayup
:thumbsup:
Bucky Badger 04-24-2009 05:56 PM
Sounds like they only sprayed a texture primer on the walls. Mabety you could try to go to a local paint store and see what the bigger drywall companies use....It's worth a try.
sirwired 04-25-2009 12:07 AM
Unless your landlord is a complete jerk or very inexperienced, he already expects to paint the house after you move out, and shouldn't charge you for minor scuffs, scrubbed spots, etc. Wall damage, yes; scuffed paint, no. There is a reason the house had such cheap paint to begin with... apartments and duplexes are the sole reason watery stuff like SW ProMar 700 even exists; it is made precisely for this use.
SirWired
JMoss1980 04-25-2009 12:44 AM
That's going to probably lead you nowhere.
Your best bet would be to paint everything, but if that is not part of your plan, I would go to the place you are going to purchase the paint from and bring them a sample( maybe even a piece of the drywall), or ask for a fandeck to take and match it up at your house.
And as far as paint goes, you can head to one of the seemingly dreaded 'Big Box' stores and find a lower quality paint for around $10-$15 per gallon, which is perfect for the project you are working on.
Hope I could help and, Good luck!
Bucky Badger 04-25-2009 08:24 AM
Worked for me when I rented. I was always complimented and thanked.
JMoss1980 04-25-2009 12:18 PM
Well you may be one of those lucky people who are few and far between. But I see it everyday, the same problem with the last owner/renter not leaving a quart of paint behind for touch up or matching, much easier to get in, get it matched and get out.
joenusz 04-26-2009 04:52 AM
Cheapest Solution
Go to a paint store - I'll say Sherwin Williams because I know them. Ask for a color fan deck to *borrow*. Go home and match the color as close as you can, and go back to SW. Ask for a sample quart of the color match - it will cost you $5. Buy a cheap chip brush for $1 and you can take care of every small scuff and scratch in your home. :thumbup:
Wall Paint - Beauty on a Budget
Wall Paint
