Touch Up Painting - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 01:50 PM   #1
Touch up painting
I recently bought a house. The house was painted sage green. The orginial paint was still left there so I painted over a few touch up areas that needed fixed. Now those areas are a lot darker than the orginial paint. Is there anything I can do to fix this? I have to fix other areas too is there anything I can do before I start to paint?
Kristy1983 is offline   Reply With Quote
Old 01-31-2012, 02:15 PM   #2
Gymschu's Avatar
Rewards Points: 502
Your original paint coating has faded. If you're just looking to touch up some spots, you will have to match the current faded color. Take a chip to the paintstore and they can computer match it. Buy a quart or a gallon (about the same price, really) and do your touch ups. One problem you may run into is that each side fades to a different color based on the "bleaching" effect of sunlight. In other words, the SW side will be much more faded out than the north side.
Old 01-31-2012, 04:25 PM   #3
BraniksPainting's Avatar
Are we talking about the outside of your house or inside? If outside Gymschu is right, the color most likely faded. If inside, I really can't see it fading unless it's been on there a long time or the previous owners had no window blinds. If inside, make certain you have mixed the left over paint thouroughly. Also, make certain they did not use two different sheens of paint. I've had that happen before.
BraniksPainting is offline   Reply With Quote
Old 02-06-2012, 11:58 AM   #4
Too Short? Cut it Again!
Clear coat is not going to restore faded pigment! If the color has been bleached out, you don't put it back in with clear coat. Waste of money.
Best option is as mentioned, have the faded color computer matched. Also as mentioned, it could be different on each side and even from top to bottom depending on how much the sun has hit it.
Old 02-06-2012, 12:02 PM   #5
Rewards Points: 394
Depending on the degree of fading, a repaint may be required. No clear coat will correct this.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
user1007 (02-06-2012)
Old 02-06-2012, 02:12 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Bad suggestion on the clear coat. People need to quit making crap up as they go along.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Old 02-06-2012, 03:04 PM   #7
Learning Things Every Day
Jay 78's Avatar
Why waste time even responding to that guy? It's clearly spam.
Shoulda clicked instead.
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-06-2012, 05:17 PM   #8
He was spotted but I post when I can before such are removed. People listen to idiots, I fear.
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
Touch up painting dcentuori Automotive Repairs 4 07-14-2011 08:21 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
