Touch Up Paint For A Metal Roof - Painting - DIY Chatroom Home Improvement Forum
Old 06-16-2013, 07:52 AM   #1
Rewards Points: 340
touch up paint for a metal roof
I installed a standing seam roof ,Fabral mansard Brown ,
on my porch
The rest of the roof is Composition with open metal valleys
The brown on the composition valleys has more red in it than the Mansard Brown on the metal roof valley
The Fabral paint is a Enduracote by Valspar , a silipoly coating
I want to paint the open valleys on the composition section to match the standing seam valleys
What steps should I use to ensure good adhesion on the metal ?
what would be the proper paint ? Krylon has a spray paint that is close ,
but is there a better option
kt82 is offline   Reply With Quote
Old 06-16-2013, 07:55 AM   #2
Rewards Points: 340
Old 06-16-2013, 08:43 AM   #3
Gymschu's Avatar
Rewards Points: 1,032
Anytime I have painted valleys to match the roof I brush the paint on with a Rust-Oleum type product for metal. Spraying with rattle cans is gonna take forever and leave overspray. Of course painting the valleys depends on how safely you can get onto the roof. Metal roofs are notorious for having unseen moisture on them and one step onto a damp metal section and you are toast! A good sanding of the metal valley and removal of any dust, dirt, or debris should be adequate before painting.
Gymschu is online now   Reply With Quote
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
kt82 (06-16-2013), Mr. Paint (06-17-2013)
Old 06-16-2013, 09:07 AM   #4
Metal Roofing
Rewards Points: 600
+1 rustoleum metalmax
We use it on SS to paint the metal vent flashing so they match the roof color. Also need it for any touch up that may need to be done.
I usually take a pc of the roofing material as a sample and they custom match it. If you want a dead on match thats what i would do.
Cleaning and preping your valley metal will be the most important part.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
kt82 (06-17-2013)
Old 06-17-2013, 12:35 AM   #5
Too Short? Cut it Again!
Remove rust from any exposed spots and spot prime with a self-etching metal primer. Than I would use a custom color matched rust inhibiting product for metal like the Rustoleum product mentioned. Ben Moore makes some nice metal finishes too. An exterior product should have some degree of UV protection mixed in the formula to help with fading.
The Following User Says Thank You to user1007 For This Useful Post:
kt82 (06-17-2013)
Old 06-17-2013, 06:07 AM   #6
Rewards Points: 340
rustoleum sounds like the winner. thanks for the suggestions
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Not venting a metal roof. maestro Building & Construction 16 12-13-2011 02:31 AM
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
