Old 10-16-2011, 10:05 AM   #1
Question
A top coat to make paint stick?
I just painted my old bathroom cabinets and when I was putting the hinges and knobs on I noticed how easy it was for my fingernail or screw driver to scratch off the paint. I lightly sanded each cabinet before I painted too. Is there some kind of top coat that I can apply that will help this not occur?
twrw82 is offline   Reply With Quote
Old 10-16-2011, 10:20 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
What was the paint you used? Some are MUCH better than others for cabs.
Also- it take a while (sometimes weeks) for a paint to cure to full hardness.
But it its hard to make a paint stick better by putting something on top- what is underneath, and what the paint itself is is what makes the difference.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-16-2011, 01:17 PM   #3
Gymschu's Avatar
Most of the time for cabinets, you need a BONDING primer like Zinsser's Cover Stain before applying a topcoat. The primer BITES onto the surface and gives a substrate that will accept the topcoat(S). I agree with BrushJockey that some paints are better than others at "sticking" to cabinets. I prefer SW's Proclassic waterbourne. Used it on some cabinet doors in the library area of my home and 10 years later they look great........beat up a bit, but still looking good.
Old 10-16-2011, 10:31 PM   #4
sdsester's Avatar
Acrylic and vinyl semi gloss paints take a minimum of 30 days to cure.
You can put on a second coat to build up the film thickness or a clear water-based poly over them once cured with possible good results but as mentioned, if there is nothing under the paint to adhere to like a good primer, top coating is not going to help much.
sdsester is offline   Reply With Quote
Tags
cabinets, old house, paint, scratches, top coat
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 01:25 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Painting melamine particle board Otchen preeatnah Painting 4 06-24-2008 11:02 PM
