Tips On Wood Glue ---- Staining Issues - Painting - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 05:13 PM   #1
Rewards Points: 278
Tips on Wood Glue ---- staining issues
Got the stairs stained.
Turns out there are areas right in the bottom of the baluster where it meets the tread --- the installer left minute glue spillout on the very edges. So it sticks out like a sore thumb (beige glue) against a dark stain.
Any ideas or suggestions on *tweaking* the glue. Granted, there is some seperation/expansion of these joints...so it's a bit more pronounced. Similar to the tread returns...edge bullnose, where in this weather , some of these have split a lil open. However, in the tread....much less glue spillout and the stain just seeps into the slight expansion crack and blends in
mobiledynamics is offline   Reply With Quote
Old 06-20-2012, 07:09 PM   #2
DIY staff
Rewards Points: 7,174
A tube of ogre and burn sienna artists oils and a touch of paint thinner--'fake it' in like an artist.
A starter set of oil paints might be the cheapest way---Some one might have a better solution--but that is what I do---Mike--
Old 06-20-2012, 07:49 PM   #3
Rewards Points: 278
I knew there was weather expansion prior to staining. But I did not see the glue against the clean white oak. It's obviously more pronounced now with the stain. I ended up taking a sharp chisel - removing some and just ran the stain rag over it. It's better....I suppose. I guess I can attempt to take a wax crayon ontop of it after the Bona traffic is applied and dry
The Following User Says Thank You to mobiledynamics For This Useful Post:
oh'mike (06-20-2012)
Old 06-21-2012, 04:14 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Originally Posted by mickelhogg View Post
You can safe your stair wood paint with mix paint fixed tube and thinner in wood paint.Thinner gives the shine on wooden paint.
Home Improvement
huh?
Old 06-21-2012, 04:55 AM   #5
Code05's Avatar
Rewards Points: 1,104
Originally Posted by chrisn View Post
huh?
It was a web bot or spammer.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
chrisn (06-21-2012)
Lots of issues - before staining concrete catchacold Flooring 7 11-25-2011 09:07 AM
glue down engineered wood floor Jfmaturo Flooring 5 03-06-2011 08:27 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
Advice needed on staining wood fence deerhunter Painting 0 10-29-2010 11:27 PM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 11:13 AM
