-   -   Tips on Wood Glue ---- staining issues (http://www.diychatroom.com/f4/tips-wood-glue-staining-issues-147718/)
mobiledynamics 06-20-2012 04:13 PM
Got the stairs stained.
Turns out there are areas right in the bottom of the baluster where it meets the tread --- the installer left minute glue spillout on the very edges. So it sticks out like a sore thumb (beige glue) against a dark stain.
Any ideas or suggestions on *tweaking* the glue. Granted, there is some seperation/expansion of these joints...so it's a bit more pronounced. Similar to the tread returns...edge bullnose, where in this weather , some of these have split a lil open. However, in the tread....much less glue spillout and the stain just seeps into the slight expansion crack and blends in
oh'mike 06-20-2012 06:09 PM
A tube of ogre and burn sienna artists oils and a touch of paint thinner--'fake it' in like an artist.
A starter set of oil paints might be the cheapest way---Some one might have a better solution--but that is what I do---Mike--
mobiledynamics 06-20-2012 06:49 PM
I knew there was weather expansion prior to staining. But I did not see the glue against the clean white oak. It's obviously more pronounced now with the stain. I ended up taking a sharp chisel - removing some and just ran the stain rag over it. It's better....I suppose. I guess I can attempt to take a wax crayon ontop of it after the Bona traffic is applied and dry
chrisn 06-21-2012 03:14 AM
Originally Posted by mickelhogg (Post 948107)
You can safe your stair wood paint with mix paint fixed tube and thinner in wood paint.Thinner gives the shine on wooden paint.
Home Improvement
huh?:huh:
Code05 06-21-2012 03:55 AM
Originally Posted by chrisn (Post 948156)
huh?:huh:
It was a web bot or spammer.
