Tips For Repainting Metal Soffitt - Painting - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 11:47 AM   #1
Tips for repainting metal soffitt
What is best way to re paint metal soffitt. Changing trim color to a lighter color and concerned with air vent holes. I am using a latex paint ( behr ultra ). Would cutting the paint with water make it easier to avoid clogging air vents?
Dan Haneline is offline   Reply With Quote
Old 04-21-2009, 02:54 PM   #2
Remodeling Contractor
no. You cannot cut this product. It already is about at the bottom of the barrel. You have chosen the worst product and will never be satisfied with the results. As well as it will last many years less than a quality paint. But, latex was the correct choice for the siding , but need to use a spray or oil for the metal soffit. The binder (PVA a plastic) is too large in latex to be used for this purpose.
Old 04-21-2009, 03:21 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
You are better off with the water to cut the paint that you are with the Behr paint. I am assumin you have alluminum soffits?
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
