Tips For Painting Older Laundry Room (lots Of Wires And Pipes...) - Painting - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 02:56 PM   #1
Tips for painting older laundry room (lots of wires and pipes...)
I would like to repaint the laundry area. It is an awful construction cone orange color and just not very welcoming. Unfortunately, I don't think the remodel will be very easy because the previous owners did an ... interesting ... job of painting it. The house is on slab and the walls are poured concrete. There are many pipes and wires to work around, some of them painted, and some of them not.
I'm not sure what the easiest way to approach the repaint is. I have attached an album of photos. Any suggestions are welcome. Thanks!
http://imgur.com/a/X1pO7
handsforasl is offline   Reply With Quote
Old 07-29-2013, 05:19 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Unfortunately, sometimes painting isn't glamorous!
I would think that a weenie roller would come in real handy is smaller and tight spots.
But basically, start at the deepest, hardest to get to spot and work your way out. You'll wear less paint that way..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
Gymschu (09-17-2013), ToolSeeker (07-29-2013)
Old 07-29-2013, 05:27 PM   #3
Sounds like I'm in for some fun...
Old 07-29-2013, 05:44 PM   #4
Too Short? Cut it Again!
That paint looks to have a fair amount of sheen to it so you will want to try and scruff it up with some fine grit paper. Then use a high bond waterbased primer like Zinsser 123 (I would get the + formula just in case you have some bleeding stains not seen) followed by a couple coats of paint store, not box store, latex/acrylic paint. For a moist laundry room in a basement, semi-gloss might be the way to go if you can stand the sheen.
With a good brush and weenie rollers like BJ suggests I think you will find it goes faster than you think and will certainly look better. As he suggests, work your way out of the room and not into it.
This is actually an application where if you had spray experience it might be worth a try. It is not worth the learning curve for such a small space though if not. It will probably go just as fast with brush and roller.
Obviously you want to spend some time prepping and washing all the wires and pipes down. Again it will just take you time but you could have a muddy looking, poorly adhering mess if you do not take the time.
If you are painting wires and pipes all the same color, make sure you can identify what they are after!
Old 09-17-2013, 02:19 PM   #5
Update: I finished today and posted pictures on the "showcase" thread. Thank you for the suggestions! Weenie roller was my friend and it was by no means a glamorous ordeal!
Remember that crazy construction-cone-orange laundry room?
The Following User Says Thank You to handsforasl For This Useful Post:
ToolSeeker (09-17-2013)
Old 09-18-2013, 01:23 PM   #6
Rewards Points: 274
That is nice that you have done.
alexjoe is offline   Reply With Quote
Finishing basement laundry room DIYguy2000 Building & Construction 7 12-04-2009 11:56 AM
