-   -   Tips for painting with dark colors (http://www.diychatroom.com/f4/tips-painting-dark-colors-21983/)
pjm 06-08-2008 04:17 PM
I'm redoing my kitchen and it's painting time. My better half picked out a nice cherry cobbler (red) color for the walls and it's driving me a little crazy getting it up smoothly. Are there any special considerations I should use when painting with a dark color like this (sanding between coats, rolling patterns)? I've never painted with anything this dark and it seems every little drip,roller edge, and other imperfections in my painting skill is showing up. I just finished the second coat and it's looking better, but I want to make sure it looks nice when i'm done.
Any suggestions or tips would be great.
Thanks in advance.
sirwired 06-08-2008 09:00 PM
Just keep doing what you are doing now. Use the absolute highest quality paint from a paint store, and nothing but the finest rollers and brushes. Apply heavily, and don't over-work the paint.
Showing perfections easily is just something that comes with using deep paint.
As far as rolling patterns go: ignore all the W/M/N pattern stuff you see in just about every DIY book/website. A full 3/8" nap roller load is enough for about a single 8' floor to ceiling stripe. Apply with one stroke, backroll with another, back-roll the previous stripe, and then re-load and move on.
When using a brush, apply with one stroke, back-brush once, and move on. Over-brushing just thins out the coating, and red requires your coats to be as thick as you can get without sagging or dripping.
SirWired
slickshift 06-08-2008 09:34 PM
One word...
"Aura"
You'll find it at your independant Benjamin Moore retailer
pjm 06-09-2008 09:06 AM
I'll give your suggestions a try. One other question. With another two coats (i think i will need at least two more) will that cover my imperfections? Or is there another way to smooth them out (sanding?)
Thanks again.
slickshift 06-09-2008 09:17 PM
Paint colors, it doesn't fill
You'll want the walls to your desired quality before applying color
In your case I suspect that will require some sanding
pjm 06-12-2008 09:20 AM
What I meant was painting imperfections such as roller marks and such. Turns out after the third coat it looked better and after the fourth coat it's just about perfect. I guess with darker colors it takes a few extra coats before it really starts looking good.
Thanks for all the help.
slickshift 06-12-2008 08:02 PM
Roller marks are generally caused by three things:
1) Poor quality product
2) Poor quality tools
3) Poor technique
As for 1, the cheaper paints show more roller marks, they just don't flow and level like the good quality ones do
The premium lines by most of the major manufacturers (Ben Moore, Sherwin Williams, Pittsburgh, California, Muralo..etc...) that supply painting contractors are pretty good
In regards to 2, it's incredible how a poor roller sleeve will leave lines (and make more work for you)
Go for at the Purdy White Dove or Wooster Pro/Super-Dooz for a good staring point
As for 3, the most common bad technique is to try and squeeze every last drop out of the sleeve
The roller should be well loaded, and the paint "applied"
No squeezing, squooshing, or mushing
Though with dark colors it can take more coats than two to get enough color on there, each coat should be free of lines
The latter coats shouldn't be attempting to hide roller lines from previous coats
MinConst 06-12-2008 08:54 PM
The last dark color (burgundy) job I did I tried a Gray primer from Gliden I forget the name of it. 2 coats of the color and it was absolutely beautiful. I don't rush these jobs. Primer and one coat first day, second coat the next. You want the first coat to dry well. Don't wash the roller and reuse it the next day. One drop of water will ruin it.
Slick has the best advice. Good paint, good tools and good technique make the job. But the right primer helps too.
pjm 06-13-2008 09:30 AM
3) Poor technique
Well I used purdy white dove rollers so I don't think that was the problem. My technique my have contributed to it as well as I used Behr paint from HD, but I've never had any problems with that paint before. Maybe there just not as good with the darker colors. I'm planning on re-painting my lr/dr in the fall maybe I will try some BM paint and see if I notice a difference.
Thanks again.
yummy mummy 06-13-2008 09:42 AM
We painted our living room a number of years ago with a cranberry colour, and I remember my husband putting on 7, yes 7, coats before it was perfect.
He said he will never paint a dark colour again..:laughing::laughing:
slickshift 06-13-2008 10:07 PM
Originally Posted by pjm (Post 130123)
...purdy white dove rollers
...My technique
...Behr paint from HD
Yes, the Behr is pretty good at roller marks, the darker the paint the more noticeable
With even a seasoned technique it's hard to not get them
