Tips For Painting Bedrooms - Painting - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 09:01 AM   #1
Tips for painting bedrooms
Hi all ..
Wife and I just bought a house. The family included 2 teenage boys, and they used the walls as cork boards for there posters. There are thumbtack and puss pin holes ALL OVER.
Rather than spackle EVERY little pin hole, is there a paint and/or technique I can use to fill in the pin holes in one shot?
Tim
timm1575 is offline   Reply With Quote
Old 08-22-2011, 10:22 AM   #2
A thicker paint will do the trick - you may have to apply two coats to accomplish the task. You should apply two coats regardless if there are holes or not - just so the sheen is consistent and the paint will perform better.
BEHR ULTA paint is pretty thick and has excellent coverage. If the walls are in real bad shape (stains & marks) then try priming the walls first with a thick primer like GRIPPER.
HDPaintPro is offline   Reply With Quote
Old 08-22-2011, 10:40 AM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
The right way to do it would be to fill the holes. You could use a lightweight compound with a wide blade knife and just skim compound all the areas where there are holes. The compound will fill the holes, then using your taping knife remove the excess from the walls. Give a light hand sanding when your done. Prime the repair spots and apply 2 coats of a quality paint with 100% acrylic binders in it from Sherwin Williams or Ben Moore. Paint is not intended to fill voids, cracks, holes ect.
housepaintingny is offline   Reply With Quote
The Following 4 Users Say Thank You to housepaintingny For This Useful Post:
Brushjockey (08-22-2011), chrisn (08-23-2011), Gymschu (08-22-2011), mustangmike3789 (08-23-2011)
Old 08-22-2011, 08:11 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by HDPaintPro View Post
BEHR ULTA paint is pretty thick, unworkable, spreads like frozen peanut butter and will sag down the wall. That should fix those pesky pin holes
I fixed that for you.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
chrisn (08-23-2011)
Old 08-23-2011, 04:31 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
PHOOEY !:laughing :
Toilet Ventilation & Kitchen Tips johnelliot Kitchen & Bath Remodeling 1 03-29-2011 10:34 AM
Difficult 12A wire..Tips suboveryde Electrical 7 12-06-2010 11:31 PM
Furnace not heating bedrooms. Bleed pipes? Sally May Introductions 2 11-30-2010 08:00 PM
Light switches not working in bedrooms MasterNES Electrical 27 08-24-2010 11:27 PM
Subpanel for bedrooms Xavier Thomas Electrical 4 04-01-2010 09:16 PM
