Tips For Caulking Trim?? - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2007, 08:54 PM   #1
tips for caulking trim??
I have hemlock door casing and baseboard. Most of the casing is installed. Most is pre-painted. The baseboard is painted & cut but not installed yet. What tips do I need when I caulk the casing and baseboard trim prior to painting? ps. I already have the walls painted. Should I plan on a second coat after the caulking of casing & baseboard????
shotdown is offline   Reply With Quote
Old 08-15-2007, 10:29 PM   #2
The main tip is to use paintable caulk (speaking from experience, here)
I like to be a minimalist with the caulk to avoid cleanup and mess. Just put a bit to cover the gaps and smooth it with your finger. There are tools you can use to smooth the caulk, too, but I've always used a finger.
And yes, you'll need to put another coat on the walls post-caulking.
StevePM is offline   Reply With Quote
Old 08-15-2007, 11:37 PM   #3
made in U.S.A.
Hamilton's Avatar
1. Paint the trim first, then cut the wall; it is much easier to cut in a wall.
2. Don't buy cheap caulk, it's thin during application and shrinks too much after drying.
3. Many times we will have to make a second pass with the gun if the first has shrunk too much after drying.
4. Use t-shirt material for wipe down rags, towels leave marks.
5. Get plenty of caulk inside of gaps of else it will shrink in time and split open.
6. Use water to "polish" the caulk in the larger joints.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Sidelight - Cannot find vinyl trim lrichards Building & Construction 2 08-28-2008 04:42 PM
How to paint trim, fascia? martyshel Painting 7 08-10-2007 09:48 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 08:49 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 02:28 PM
