Tips On Applying Tape To Prevent Paint Peel Off - Painting - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 09:08 PM   #1
Rewards Points: 290
Tips on Applying Tape to prevent paint peel off
Put tape on a edge.....where paint met wood trim. Needed to do some sanding on the wood. Did not want to touch wall.
Aura Paint - Matte - 3 weeks old .
Blue non edgelock 3m tape.
When I removed the tape....it removed some of the pain (from where the edge meets the trim and then some).
I guess it happens to all of us.
Any tips on how to prevent this from happening ?
mobiledynamics is offline   Reply With Quote
Old 06-19-2012, 09:25 PM   #2
Rewards Points: 526
Four thoughts:
Give your aura paint more time to cure.
Leave the tape adhered to the surface for as little time as possible.
Use the specialty blue tape that is designed for delicate surfaces.
Paint coming off could be sign of adhesion issues between coats.
Windows is offline   Reply With Quote
Old 06-19-2012, 09:30 PM   #3
Rewards Points: 290
I'm thinking it was a combo....
As the edge was a cut in edge....in which the edge was not 100% fully adhered to the wall, as when I removed the tape while the paint was wet previously....there was a smigen of lifted paint ...not a hard clean edge. I was planning to take a blade and clean up the edge when all the renov was done. I suppose the paint stuck to tape on this *lifted* edge and peeled along with it.
Old 06-19-2012, 09:45 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
I often will run a putty knife or a dull pocket knife ( oh yes- i have a swiss miss for just this!) on the edge of tape before pulling. Prevents pull up on the wall.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-19-2012, 11:13 PM   #5
Put tape up, paint edge, pull tape off immediately while still wet...
pucks101 is offline   Reply With Quote
Paint Pulled Off With Tape AllBoys Painting 10 11-11-2011 09:08 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Damaged paint when removing tape somuchjackson Painting 11 08-10-2011 07:07 AM
Paint is peeling off when I lift masking tape! Help! HelloMotto Painting 10 07-15-2009 08:53 PM
Where to begin Boston Painting 4 06-15-2006 06:39 AM
