Time For Painting Second Coat - Painting - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 08:30 PM   #1
Time for Painting Second Coat
If your pressed for time to finish a room, how long do you have to wait before a second coat of paint can be applied on the walls? Do Flat paints dry faster than Satin or Gloss? Tempature in house is 65 degrees.
Dougit is offline   Reply With Quote
Old 01-27-2008, 09:33 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Depends mostly on the paint (exactly what type/brand/line/etc)
But also on the temp/humidity and other conditions
A good paint in good conditions (Ben Moore Regal 70* 50%) you might be able to push it to a few hours
Ben Moore Aura about 40 minutes no problem
slickshift is offline   Reply With Quote
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Time between coats of paint/primer joeyboy Painting 19 09-23-2007 09:15 AM
