-   -   Time to paint ~2500 wall sq. feet (http://www.diychatroom.com/f4/time-paint-2500-wall-sq-feet-12416/)
Shpigford 10-15-2007 04:21 PM
So my wife and I have the overwhelmingly fun task of painting the entire interior of our home.
The walls will already be a plain white so we shouldn't need a primer.
The approximate wall square footage will be around 2,300-2,500.
We've never painted this much space so I'm curious about how long it might take 2 people to paint this. As of now we're just planning on going the traditional roller/brush route of painting all of this.
joewho 10-16-2007 09:34 AM
Very general question there. Have you painted before? Have you painted before, with your wife? :)
The time will get eaten up on trying to cut in the ceilings, especially with deeper colors.
There are other variables, ie: is it furnished? Is the trim being taped off?
What colors are you using? Kitchen and baths too?
Shpigford 10-16-2007 09:39 AM
Sorry for the lack of info. Shows our experience (or lack of) with this. :)
We have both painted rooms in a house before but never an entire house...just a single room here, a single room there. And yes, we've painted together before. :)
It will not be furnished and we'll be taping off everything under the sun (trim included).
For the most part everything will be a mid-tone beige color. There will be one wall that is a blue color and another room that will be an entirely different color altogether (not sure what yet).
Baths - yes. Kitchen - no.
Hope that helps. :)
sirwired 10-16-2007 10:21 AM
If you want to save a very large boatload of time, don't tape off all the trim. Using a quality brush and with a little practice, all but the most clumsy homeowner can work much faster, and end up with a better looking result by not taping off door and window casings.
Tape has the disadvantage that paint almost always leaks under it somewhere, and usually ends up slightly crooked, which sticks out like a sore thumb.
Personally, I used a masking machine (combination tape and masking paper dispenser) to tape off my quarter-round, but that was it. I left the door and window casings alone.
SirWired
NateHanson 10-16-2007 11:41 AM
I agree with the taping advice.
As far as primer, I've always gotten a more even finish when I use a coat of primer regardless of color. It's been described to me as the glue that holds the paint to the wall. Not sure what the expert opinion on here is, but my understanding is you should use primer regardless of the current color.
Are you painting trim as well, or just walls and ceilings?
For my wife and I, it takes about a days worth of actual work time to paint a large room with trim. Maybe half a day without trim. (that's subtracting all the drying time.) One of us is chasing kids about half the time though.
Is 2500 sf the WALL area you're painting? Or is that the floor area of the rooms you're painting. If it's walls, it doesn't actually sound like that much, considering that a 200 sf room is about 500 sf of wall space, so you're talking about 5 rooms?
Shpigford 10-16-2007 11:47 AM
Hmmm...interesting. I'd certainly be interested in hearing some other thoughts on that. The fewer times we have to go over the wall with a brush, the better...but I certainly don't want it to look bad because we took a shortcut.
Just walls and possibly not even ceilings...but no trim.
It's my estimate of the "wall" area. It's a 1400 square foot home with the first floor having 9 foot ceilings and the 2nd having 8 foot ceilings. It's a realllllly rough estimation and doesn't include subtracting stuff like doors, windows, cabinets, etc from the equation. We'll be painting a living room, kitchen/dining, stairs/hall, 3 bedrooms, a laundry room, and 2 1/2 bathrooms. The kitchen won't consist of much as almost all of it is cabinets and stone/tile.
NateHanson 10-16-2007 01:53 PM
Any time I've skipped the ceiling, I've been disappointed, and gone back to do the ceiling after putting a coat on the walls. Ceilings never look dingy until you put some nice fresh paint on the walls! And ceilings are really really quick work. You can roll a coat of flat white wall paint on in about 20 minutes, and I usually just roll right along the corner, getting paint on the walls, but covering the ceiling right to the edge. Then paint the walls second, and you'll cut them in, but no need to cut the ceiling paint in.
My $0.02, but it's your house, so make your own decision. :)
Shpigford 10-16-2007 02:05 PM
Well we aren't planning on painting the ceiling because they'll already be painted white by the builder...it's just that not only will the ceilings be painted white, but so will the walls and trim. Hence us wanting to paint all the walls in the house. :)
At any rate, does anyone have any guestimates on time? :)
I'm really just looking for something rough like "around 30 hours" or "around 80 hours." Basically wondering if this will take us like 2 days or 5 days.
NateHanson 10-16-2007 02:29 PM
Ah! I see. :) I'd guess more than 2 days. If it's clean and freshly painted then I might skip the primer, and just plan to put two top coats on everything. Primer seems to help when walls are a little dirty or worn, or have some spots that I've just patched. But in your case, probably not necessary. So two coats per room, I'd say 3 hours to do a coat in one room, if there aren't too many doors and windows to cut. Another 3 for the second coat. You've got about 7-ish rooms, and two people working, so maybe 20 hours of actual work for the 2 of you. What's that? 3 days? I should add that I'm a chronic underestimator, so better give yourselves 5. :)
So no chance of slipping the builder some other paint colors, eh? Seems a shame to paint a house twice!
Shpigford 10-16-2007 02:34 PM
Yeah, we'll be painting it about 10 days after it's all painted the white color.
So what dictates needing 2 coats? Is it just that way with all paints? Or is it based on the darkness of the paint?
sirwired 10-16-2007 02:41 PM
That is just the way with all paints. (Dark colors may require additional coats, especially if applied by an inexperienced painter.)
For me, even with a small color change I know that with a single coat, there are still going to be little "pinholes" or thin spots. Maybe a pro could get away with a one-coat color change, but most won't even try.
SirWired
NateHanson 10-16-2007 02:51 PM
Exactly my experience. A couple times I painted with one coat, and it looked fine, so I left it, but both times I later noticed that there were patches with these "pinhole" spots where the roller didn't completely cover the old color or primer below. Now I always do 2 finish coats.
ron schenker 10-16-2007 02:56 PM
It sounds like this is a brand new house. If it is, be forewarned that you will see numerous nailpops in the first year that will probably ruin the look of your beautiful new paint job. It is recommended to wait at least a year until all of the house settling is finished, then have the builder come in and repair these at no charge. I know it's nice to paint before the furniture goes in, but just a head's up.
Shpigford 10-16-2007 02:57 PM
Great tips so far (especially on the needing 2 coats...).
Any other guesses on a rough time estimate to complete all of this?
NateHanson 10-16-2007 03:07 PM
I'd go ahead and paint. You can always touch up any nail-pop repairs down the road. Make sure you save paint from each room.
