Thompson Tinted Water Seal - Painting - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 06:26 AM   #1
I couple years back, I sealed a cedar bench with Thompsons Tinted Water Seal. It was a disaster. It just never dried. It stayed tacky. And looked bad on top of it. I figured it would eventually dry, but even though you could sit on it, it still felt gummy.
So last year I tried sanding it off. I was only able to get about half of it off.
Any suggestions for what I should try next? Could I paint it the way it is? Not really the look I wanted, but not sure what to do with it.
Do you think stripping would work? Even after sanding, it doesn't seem very smooth anymore. Kind of like the grain is raised.
paullo is offline   Reply With Quote
Old 03-28-2013, 07:15 PM   #2
cdaniels's Avatar
Sounds like the Thompson's wasn't stirred enough.I have used it once on a deck and it was a bear to mix.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-29-2013, 01:10 AM   #3
Too Short? Cut it Again!
Thompson's Sealer, tinted or not, is a horrible liquid wax based product. You have to strip it as you would floor wax. Usually the stuff weathers and falls apart after a season. If you got the lucky pail? I guess you have to go to a janitorial place and get a wax stripper on the cheap?
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (03-29-2013)
Old 03-29-2013, 07:39 AM   #4
Gymschu's Avatar
Rewards Points: 180
Welcome back SDsester!
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
