Thinning Solid Stain - Painting - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 11:23 AM   #1
thinning solid stain
Can I thin Bahr solid stain to get it through a pump up sprayer
patandsusan is offline   Reply With Quote
Old 04-08-2012, 12:22 PM   #2
Rewards Points: 13,250
I'm sure you could but then the stain would be about useless.
What is it your trying to spray? If it's a deck do not do it. It's just not going to put enough stain on the wood to make it worth while, and there will be to much over spray and it will end up on the siding.
You would be better off using an airless sprayer if you trying to stain something.
Old 04-08-2012, 12:32 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If you are using Behr it's already pretty much useless. Get a decent brand of stain like Sikkens and apply it properly.
Darkling Designs
poppameth is offline   Reply With Quote
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 09:37 AM
Confused about Solid Stain vs Paint Earnie Painting 10 03-01-2012 02:56 PM
black oil based solid stain ugabulldog Painting 1 11-10-2011 11:16 AM
Solid Color House Stain djg Painting 4 08-30-2011 07:52 AM
Solid GRAY STAIN for pine furniture? smoochas Painting 1 08-08-2010 02:58 PM
