Thinning Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 08:46 AM   #1
Thinning Paint
Hi Guys,
Is there ever a reason nowadays to thin paint? I say this because I imagine that all good brands such as Benjamin Moore, Sherwin Williams, etc. are probably thinned to the correct consistency in production.
Thank you,
Bob
Bob Guercio is offline   Reply With Quote
Old 04-03-2011, 08:54 AM   #2
Coatings Nerd
The only reason guys thin, is to achieve the application properties that they like. Most products are built to fit the masses. Thinning something slightly to make it apply the way you want is ok. Most products will state that on the label.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 04-03-2011, 09:01 AM   #3
Agreed. We thin latex with XIM Xtender and alkyds with Penatrol. Probably more out of habit than anything, although I do like a certain "flow" when I cut. I do find that most low/no VOC paints need to be thinned to maintain a wet edge.
kboyz is offline   Reply With Quote
Old 04-03-2011, 09:08 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Same here. It just makes it flow better.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-03-2011, 10:45 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
I seldom just open and go. But how much and when is largely a matter of feel and experience. And every paint is different to some degree.
Brushjockey is offline   Reply With Quote
Old 04-03-2011, 11:45 AM   #6
Super Master Painter
Ole34's Avatar
id also like to add that thinning is helpfull when painting exteriors or in direct sunlight to retard dry time
Ole34 is offline   Reply With Quote
Old 04-11-2011, 09:51 PM   #7
NACE Coating Inspector
mustangmike3789's Avatar
some of the coatings that i use are 70% to 100% solids and thinning is required. these guys are right. thinning will help with flow and keeping a wet edge. i use a lot of epoxies and polyurethanes and i cant thin them as much as i would like to anymore due to tighter VOC regulations. thinning will be different for each application (brush,roll or spray). your product should have guides for thinning on the can or you can request a product data sheet from your paint supplier.
mustangmike3789 is offline   Reply With Quote
Old 04-12-2011, 09:47 AM   #8
Nothing wrong putting some latex speed.
StevenH is offline   Reply With Quote
Old 04-12-2011, 03:18 PM   #9
Too Short? Cut it Again!
Never painted interior latex trim without a bit of Floetrol but I wouldn't call it thinning.
Old 04-12-2011, 05:55 PM   #10
Is Floetrol a substitute for a good quality paint? In other words, since I use Benjamin Moore Regal, would Floetrol be of benefit to me?
Bob
Old 04-12-2011, 06:03 PM   #11
Ole34's Avatar
Bob
first of all its not a substitute but rather an additive........i use ''aquatrol'' its cheaper
Latex paint conditioner improves flow and cover qualities while it makes brushing, rolling and spraying easier. Reduces brush marks and bristle separation. Permits 20% lower spray pressures when spraying. Creates the beautiful look of oil-based paint. Reduces brush and roller marks. Extends open working time. Great for faux finishing, painting of trim and paneled doors. Soap and water clean-up.
Old 04-12-2011, 06:39 PM   #12
Exactly! I used top end paints but it still added a lot to the final surface look. I didn't do a lot of spray work but those who did loved Floetrol and its cousin Penetrol for oil based finishes.
In the art world, where I thought I was headed once, Liquitex makes a similar product but a tiny can of it starts for $25 or so these days? Thankfully I also grew up in and around the trades and learned to paint art galleries because I never would have made it as a fine arts painter.
I've never tried aquatrol and it may not be marketed where I am or I just have not noticed but will give it a shot. A gallon of Floetrol went a long way when I was working steadily. A quart of Floetrol, or I suppose Aquatrol would last a homeowner quite awhile and I think it retails for like $8-10 for a quart?
People please listen, it will not fix crappy waterlogged box store paint. You got to use it with real paint.
Old 04-12-2011, 06:46 PM   #13
Hi Guys,
Thank you,
Bob
Lost site of your question and rambled on. Sorry.
Yes, there is probably a reason to thin paint. You may have trouble getting it through the crappy Wagner-ish spray equipment if you don't. Don't buy paint toys and expect anything much out of them!!!! Rent the good equipment and buy your own tips to be safe if you do not use it often.
As mentioned, I have not done a lot of spray work in awhile because I ended my painting career working on antique and vintage homes where it was just not appropriate in most cases. Last time I used one? A cutie of a Victorian that was getting new floors and had 800 closets, cabinet interiors, nooks and crannies that got the only white paint in the place. I also mickey mouse masked all the clean and prepped trim and primed it. Some goth kid had painted her bedroom black so I primed that with a sprayer. 4,000 sf of such nonsense done in a day.
If the rugs and floors were special? And I showed up with spray equipment? And even with TRUST ME on my shirt and a bottle of Floetrol?
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
thinning out thick paint/drips before new paint bonanz Painting 3 09-24-2007 12:31 AM
