thinking of staining/sealing deck
Decks need to be washed every year and re stained accordingly every 2-4 years depending on the type of stain you use. The key is proper preparation. When washing the deck use a quality deck wash and a pressure washer with low pressure 500-800psi is sufficient. After washing and removing all of the grey, which is dead wood fibers then apply a brightner, this will brighten the wood, remove any rust from nails, and open the pours. Then sand as needed. Moisture test and apply a quality stain. Sherwin Williams, Sikkens, Cabott. Using the right cleaners you can take the dirtiest of decks and have it looking like new again. Most people never use a brightner or remove all of the gray. I prefer to use a per carbonated deck cleaner which does not contain bleach, bleach actually has long term affects on wood.
