Thick Paint To Help Amateur Drywall Job - Painting - DIY Chatroom Home Improvement Forum
Old 07-26-2007, 08:21 PM   #1
Send a message via Yahoo to fburke
Thick Paint to help amateur Drywall Job
I did some drywall work in a hallway and let just say it looks ok but not perfect.
I was wondering if there is a thick paint available that I could use to cover my blemishes.
It doesn’t look too bad you can see some lined from my taping knife that will smooth out but still a little help would be a good idea.
Thanks!
fburke is offline   Reply With Quote
Old 07-26-2007, 08:29 PM   #2
They have texture paint to cover up minor flaws but it may be in your best interest to spend a little more time and get the walls to look better.
How many coats of compound did you apply?
What are the flaws that need to be fixed?
redline is offline   Reply With Quote
Old 07-26-2007, 08:54 PM   #3
The wall was in pretty rough shape lots of glue from wall paper I got off as much as I could and the lower portion was paneled and they used glue to stick it to the wall..
I skimmed coated it to the best of my ability but it’s far from perfect it’s a stair well so it’s a difficult area to work in, I’m not looking for perfection at this point just presentable.
I just bought another house and I am moving out next month and I just rented this unit so I just need it to look presentable for my new tenants.
Old 07-27-2007, 12:18 PM   #4
Is this wall drywall or plaster and lath?
how large of a wall area is this?
Old 07-29-2007, 12:40 AM   #5
DEpends upon the type of wall.what is the type U have.and what is the coulur.bcs darker colour and lighter colour needs to be dealt with diffrently
HiFi is offline   Reply With Quote
Old 07-29-2007, 08:35 PM   #6
remodeling pro
Do some extra work on the drywall. you cannot hide bad drywall work with any amount of paint.
troubleseeker is offline   Reply With Quote
Old 07-29-2007, 09:31 PM   #7
Paint/Faux Artisan
Da Vinci's Avatar
I agree- no paint is thick enough to hide a bad patch job. That being said, painting everything off-white, will help. The cheaper the paint the better, because the more expensive flats still have a slight sheen due to the quality and resins. The cheap stuff has lots of fillers that actually make it even more flat.
But patching would be best...
Bay area Painting Company
Da Vinci is offline   Reply With Quote
Help!!!! Paint Woes ra_doliv Painting 4 07-19-2007 09:15 AM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
what's good paint / drywall finishing elementx440 Painting 4 03-15-2007 10:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
