Thanks For Primer Hints - Painting - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 03:37 PM   #1
Rewards Points: 2,166
thanks for primer hints
Asked the paint store about tinting primer, after reading posts about it here. Otherwise wouldn't have even known about it.
Yes, to paint my LR from a medium yellow to light taupe, (the color of coffe with cream) he suggested a light gray primer.
THANK YOU TO ALL THE PAINTERS ON HERE.
Startingover is offline   Reply With Quote
Old 05-22-2012, 05:55 AM   #2
I wouldn't imagine that color change would require a primer. The gray under the taupe might muddy the final appearance a bit. Sorry to throw a monkey wrench in your certainty. If you already have the gray, and some time, in an out of the way area, do a small square of primer and then do a larger sqaure of finish to see how the final color looks over the yellow and gray. Keep us posted.
Old 05-22-2012, 07:12 AM   #3
I now understood the importance of the paint stores color charts, on the back side, there's a chart which tells the optimum color results using the designated Color-Prime and also LRV, light reflective value.
My entire life I've just slapped a coat of paint on the wall. But until now, I've never painted with strong colors.
Also, I'm really, really happy that my paint store is having a sale this weekend and I'll buy all the paint I need and just take it back to be shaken as I use it.
I was shocked at the price of some paint.
Hints for pulling new wire through old wall? bcarl Electrical 5 01-25-2011 11:09 AM
Need to fix old plaster on brick wall - any hints? Leah Frances Building & Construction 1 01-14-2010 05:55 AM
SW ProClassic Waterborne Enamel - hints on apply to trim? vsheetz Painting 8 01-10-2010 06:42 PM
vinyl siding hints daval Building & Construction 1 05-09-2009 10:08 PM
vinyl flooring hints wilderstyle Flooring 14 12-03-2008 04:51 PM
