Texturing Walls - Painting - DIY Chatroom Home Improvement Forum
Old 01-30-2009, 04:17 PM   #1
Texturing walls
Evening everyone! Has anyone ever added primer right to the texture being sprayed on a wall...does that work?
S&R Painting is offline   Reply With Quote
Old 01-30-2009, 04:35 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Depending on the texture you might be able to but...
It would only cut the effectiveness of the primer and could (seriously) adversely affect the quality of the texture
So it wouldn't help cut out a step or anything, just make the over-all project worse (more likely to turn out badly or lead to an early - or immediate - and unwanted failure)
slickshift is offline   Reply With Quote
Old 02-02-2009, 06:24 PM   #3
Drywall contractor
Rewards Points: 1,070
I have added paint to drywall mud to get a desired color for a texture, but not to replace proper prime coat. Raw sheetrock needs primer!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 09:48 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Texturing over painted walls l1r Painting 3 08-05-2008 10:52 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
