Texturing Problem - Old Moulding Removal - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 02:06 AM   #16
Rewards Points: 87
Ok I was mistaken then. So that requires some skill, you say. Is it difficult to find one who is skilled in this art? Cause I would like to have my textured walls, turned smooth.
Bennylava is offline   Reply With Quote
Old 06-01-2013, 08:08 AM   #17
Jmayspaint's Avatar
Rewards Points: 534
A good drywall finisher can do it. It does take some skill. The average painter could probably pull of doing a wall or two, maybe a small room.
But to do a whole house with any kind of efficiency, its gonna take a guy that has a lot of exp. with mud.
The more skill the person has with skimming the mud, the less sanding is required. And that's important if your doing a lot of it.
I can do a wall if I have to, takes a lot of sanding though. And a couple more coats than it would take a good mud man.
Yea, get a reputable dry wall finisher. Shouldn't be that hard to find.
Jmayspaint is offline   Reply With Quote
Old 06-02-2013, 06:30 PM   #18
Rewards Points: 87
So do you absolutely have to put mud on when you put up new drywall? Is it a requirement? What would it look like if you simply put up the drywall, taped and bedded, and then painted? With no texture or mud of any kind.
Old 06-02-2013, 07:09 PM   #19
Rewards Points: 5,974
Are you talking about tearing this out then new drywall or attempting to just cover with drywall? And why would you consider either? And no on new drywall just bed and tape. Seal the torn drywall paper with Gardz, sand, then skim coat.
Radiator spud removal problem Quercus HVAC 9 06-28-2012 10:00 PM
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 10:37 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 03:46 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
