Textured Walls - Painting - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 11:05 PM   #1
Textured walls
Hi I am wondering how to clean textured walls that haven't been painted. I can't wash them with anything wet as it removes the textured coating. I would really like to paint the walls but don't know what to do about the grime. Plz help!
Cluedout is offline   Reply With Quote
Old 09-01-2012, 11:12 PM   #2
Rewards Points: 81
They haven't been painted but they are grimy? What happened? What kind of texture?
Total Tool is offline   Reply With Quote
Old 09-01-2012, 11:59 PM   #3
The house came with textured walls but no paint. Husband says its called knock down. I wanted to paint them right off the bat but husband said not yet. So here we are almost four years later (we have kids) and the walls are quite dirty in many spots.
Old 09-02-2012, 01:50 AM   #4
Just use a primer over the wall I am in property management so I deal with dirty walls a lot. Just primer and paint.
afrye707 is offline   Reply With Quote
The Following User Says Thank You to afrye707 For This Useful Post:
Cluedout (09-03-2012)
Old 09-02-2012, 03:16 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
not a wise idea , at all, you need to clean them first
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Old 09-02-2012, 07:31 AM   #6
Too Short? Cut it Again!
I suppose in a property management situation where you do not care about longevity and washability of the surface because you will paint it when the apartment turns over in months or a year you could try this approach but for a homeowner that does want the paint job to last you cannot skip the prep.
You risk an adhesion issue if you do not clean them. Priming and painting dirt and accumulated household oils/grease, kid prints, etc. could (probably will) come back to haunt you.
It sounds like it is a drywall knockdown of some sort and the compound will dissolve to a point with water. I would use a large car wash sponge with a light touch. I would make several passes with it fairly dry rather than saturating it with water. Don't panic if some comes off as that is to be expected.
They've always struck me as rather gimmicky toys but perhaps this is an application for one of those steamer cleaners if they do not saturate the walls too much. Anybody else tried them on walls?
The Following User Says Thank You to user1007 For This Useful Post:
Old 09-02-2012, 10:49 AM   #7
Rewards Points: 13,750
Mr. Clean magic sponge.
Old 09-02-2012, 11:38 AM   #8
Then wash the walls and texture where needed and paint.
Textured walls need a patch kattcs Painting 3 06-22-2012 11:25 AM
Textured walls Bosslady7171 Drywall & Plaster 3 06-01-2012 05:24 PM
glossy textured interior walls susan henderson Painting 23 08-20-2011 03:54 AM
Textured High Gloss Enamel Walls Jwolf24601 Painting 4 02-19-2009 08:26 PM
Anything to keep in mind with painting textured walls? Shpigford Painting 4 10-17-2007 11:22 PM
