Textured Paint - Painting - DIY Chatroom Home Improvement Forum
Old 12-06-2007, 09:12 AM   #1
Textured paint
I need to paint a small room, and want to use textured paint. Is it better to buy a paint that is already textured (Valspar), or to buy the texture mix and add it to the paint? Also can you use a roller to apply these paints?
TH72 is offline   Reply With Quote
Old 12-06-2007, 07:06 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
I think in general you can get a better mix (more even texture) with the factory textured paint
But you still have to take care to continue mixing while applying
That doesn't mean with a little effort one can't get a DIY mix to work, and work well
Just in general with the pre-mixed I think it might be a little easier
Of course that could depend on the texture also
And yes a roller should be fine
But again, it could depend on the texture
...there could be textures where it's not advised
slickshift is offline   Reply With Quote
Old 12-07-2007, 05:56 AM   #3
Guest
Guest
Posts: n/a
Pratt and Lambert makes a couple of textured products. They spec a specific kind of rollers for their stuff. Honestly though I've had people use P&L's roller and normal Wooster rollers with it and have good luck either way, so I don't think the roller is as important as they want you to believe.
Old 12-07-2007, 11:32 AM   #4
Thanks for the input
Old 12-07-2007, 02:21 PM   #5
I recently re-textured our living room. I went with an additive from Menards. (Can't think of the name of it right now. They had fine, medium, and coarse. We went medium)
Here's what I noticed.
1. You need WAY more paint to cover the walls than you do for straight paint. I went through almost a gallon of paint that I added the texture to when I could have painted the same area with about 1.5 quarts of regular paint.
2. I noticed that the texture really didn't adhere to the wall when you first put it on. What worked best for me was to roll the paint onto a workable area, then go back when the paint was "tacky" and all sorts of texture then adhered to the wall. Takes a bit of getting used to to get even texture. There's some over-textured areas on my walls, and some that are under-textured but unless you're really looking for it (as I do since I painted it) you wouldn't notice.
Good luck!
Eric
perpetual98 is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 09:42 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
paint textured with crushed stone. ouchmythumb Painting 5 05-12-2007 07:45 AM
