Textured Ceiling Paint Cracked And Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 08:39 PM   #1
Textured ceiling paint cracked and peeling
My ceiling is textured and painted, in one small area, 2 crack lines (about 1 feet in length each) has appeared and the texture and paint seems to be peeling a little.
It looks like this:
I checked and there seems to be no water damage and it is not getting worst. The crack/peel had stayed like that for a long time, over a year, I was just lazy to do anything about it until now.
How should I go about repairing this? Peel off the crack part and then texture the ceiling again and then paint over?
I've seen Home Depot selling those small spray texture product, can I use those for this small area?
Thanks.
bigbearbear is offline   Reply With Quote
Old 09-19-2012, 09:19 PM   #2
Gymschu's Avatar
Rewards Points: 646
Kinda hard to say what's going on there. It almost looks like wallpaper seams. There are wallpaper products out there that look like texture........you apply just like wallpaper and then paint it. If that's not it, it appears to be seam cracks. You will have to dig out the torn paper, remud & re-tape and then try to match the texture. Matching texture is no simple task. That looks like orange peel sprayed from a hopper. Your best bet may be to buy one of the cans of texture and give it a shot as setting up a compressor to re shoot the orange peel is a tall task.
The Following User Says Thank You to Gymschu For This Useful Post:
ToolSeeker (09-26-2012)
Old 09-20-2012, 05:01 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 296
If the splits are 20and 1/2 inches apart it's wallpaper
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (09-20-2012)
Old 09-21-2012, 02:01 AM   #4
Too Short? Cut it Again!
My guess is some sort of surfacing material like NuWal put on wrong. Or some sort of vinyl resurface product. I will defer to Chris though since he is the paper guy.
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
Painting a textured ceiling computerdude103 Painting 4 06-28-2009 11:43 AM
peeling paint on plaster ceiling mspdet Painting 9 12-13-2008 07:45 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
