Textured Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 04-05-2008, 07:44 PM   #1
textured ceiling
I got a bathroom ceiling that is textured I want to give it a new look How do I remove it a piece is already gone by the fluorescent lite it fell off during installation of the light help please
terrib is offline   Reply With Quote
Old 04-05-2008, 07:49 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 852
First off, What kind of texture is it? Sounds like Popcorn texture. Is it?
Sir MixAlot is offline   Reply With Quote
Old 04-06-2008, 07:24 PM   #3
textured ceiling
yes it is...and I know it is painted on as the piece that came off left an ugly yellow behind.....I know it probably needs to be all scraped off but how does one do that? then can I just put the primer with the moisture barrier kilz and then just repaint.?
Old 04-06-2008, 09:15 PM   #4
Rewards Points: 852
Could the yellow be a water stain? To get the stuff off: 1) Cover evrything in the room w/ plastic. 2) Get a pump garden spayer and wet ceiling only. Depending on the size of the ceiling, you might just want to do 3' x 4' sections so it doesn't dry before you get to it. 3) Next you need to get a 4" or 8" putty knife and a two strap sanding/dust mask. Start scraping the wet area after it has soaked in for a few minutes. (you might need to do this procedure twice if the popcorn was painted). Yes, I would use the oil based Kilz for stain blocking before painting. Depending on the condition of the ceiling underneath the popcorn you might need to do a little mud work. Typically popcorn is not sprayed in bathrooms because of the moisture issues in bathrooms. S.o, hopefully it wasn't sprayed in there to cover something up. Good luck! Let us know as it progresses
Old 04-07-2008, 02:05 PM   #5
ceiling repairs
thanks very much....I do know that the yellow by the light was the previous paint scheme as the walls were the same color before we added some wall panel coverings .......I think doing it ourselves small portions would be the best and thanks for telling what to do . I do appreciate it and will send you all an update....thanks again.....
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 10:42 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Repainting large section of textured ceiling? ChrisT Painting 2 02-12-2008 01:54 PM
Can drywallers cut into existing textured ceiling? wease Remodeling 2 12-23-2006 01:40 PM
Textured Ceiling jerome8283 Painting 6 08-21-2006 12:10 PM
