Texture Technique - Painting - DIY Chatroom Home Improvement Forum
Old 02-10-2008, 03:23 PM   #1
Texture technique
I'm trying to figure out a texture technique that I've seen. It's smooth with tiny holes (almost like termite holes)...??? Not sure how to explain the look, but does anyone know the technique and how it is acheived?? Thanks!
Txmomof2 is offline   Reply With Quote
Old 02-10-2008, 06:54 PM   #2
Here is a supplier of Venetian Plasters that I've worked with...
http://www.permatone.com/applicationGuide/Sabbia.html
down the left side are a bunch of different products that they have, which will likely get to what you're looking for.
I would warn you that these are pretty complex applications and not likely something that can be done without training. There are a few that will get you half way there that you could probably try out. If I find some info on the DIY designed products, I'll post them.
DIYHelper is offline   Reply With Quote
Old 02-10-2008, 06:57 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hmmm....Very Interesting....
- Build Well -
Old 02-10-2008, 07:15 PM   #4
This is a more DIY friendly set of stuff...still takes a little work though.
http://www.modernmasters.com/products.aspx?pl=TE
Old 02-10-2008, 08:14 PM   #5
Pro Painter
I think he is talking about knockdown ceiling type texture.
http://www.minnesota-painter.com/knockdown.html
TroyM is offline   Reply With Quote
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
Steps for putting texture on new drywall TNeat Remodeling 4 12-22-2007 06:39 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
first time using a texture gun samf Remodeling 9 12-14-2006 07:16 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
