Texture Is Off Around House. - Painting - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 07:42 AM   #1
Rewards Points: 384
Texture is off around house.
We've been doing a lot of repairs and large patches have been put into place and we're noticing that the texture doesn't match which bugs me. Here is an example, see around the switch how smooth it is? Any tips for blending this?
It's much more noticeable in person than in the pictures. :-)
RyanD is offline   Reply With Quote
Old 11-04-2013, 08:13 AM   #2
Rewards Points: 12,876
I'd repaint the whole wall with a 1/2 nap roller.
Old 11-04-2013, 08:14 AM   #3
Gymschu's Avatar
Rewards Points: 240
That is fairly common if some patching has been done. It's very difficult to match the old "stipple". There's things you can try such as using a thicker nap roller, but, to be honest, you will likely NEVER get it to match.
Gymschu is online now   Reply With Quote
Old 11-04-2013, 08:18 AM   #4
Jmayspaint's Avatar
Rewards Points: 534
What we do to blend nap texture like that is roll the patches with Cover Stain before painting. The oil primer seems to build up nap better than just using the wall paint, or latex primer.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (11-04-2013), ToolSeeker (11-04-2013)
Old 11-04-2013, 08:43 AM   #5
Painting Contractor
Rewards Points: 87
Looks to me like you have a light blown on texture that has not been knocked down, rather than a rolled on stipple finish. The drywall contractor should have blown on a texture to match when he finished. The best way to match that texture is to rent a hopper gun if you want to do it yourself, and blow on a light texture to match, or else hire a drywall contractor to do the texturing. I have never had luck with the spray can texture. It will hardly be noticeable if done correctly.
kkeith is offline   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
How do you get a sandy texture finish when painting in the house mjeffersondc Painting 12 11-15-2011 09:29 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
