Old 03-19-2008, 04:42 PM   #1
analogmusicman's Avatar
texture on new wall
I plan on spraying texture onto this new wall I just built (with a compressor and texture gun, those cans are both a nuisance and expensive) my question is when does the texture go on, before or after the primer? does it matter?
tnx,
analogmusicman is offline   Reply With Quote
Old 03-19-2008, 04:48 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
texture on new wall
There are two opinions that go around about this.
My take on this, is that texture is primarily joint compound. You apply joint compound onto sheetrock. You don't prime sheetrock before applying compound to it.
That is why we always apply texture first, then prime over it.
- Build Well -
Old 03-19-2008, 09:31 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
texture on new wall
Technically the texture should go on after the primer, then be re-primed
However, it's rarely done this way in new construction
slickshift is offline   Reply With Quote
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 12:57 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
